Hello,
sorry for my trivial question but I was not able to understand the schematics of the Sparkfun Pro Mini.
Practically, I have started soldering for the first time and I begin with the Pro Mini (maybe not a good idea).
Pics attached.
Because of my unsteady hand, I wanted to check the joints through the continuity test of my multimeter.
I did two types of checking
the same joint one lead to the header on the front and one lead over the solder on the back
two adjacent joints to see if I created an unwanted bridge
I notice that everything seems fine except for BLK and the adjacent GND. There is continuity between these two joints. Is it ok or did I mess up?
srnet:
Which of the connectors on that schematic looks most like the programming connector on the Pro Mini ?
A good clue is that the Pro Mini programming connector has 6 pins ......................
It shpuld be JP1 (FTDI basic) and although the order is completely different, by exclusion, BLK could be denoted as DTR. In any case, I cannot see any connection between them. So, I should not have continuity?
srnet:
Rather than show a new schematic image it would be best to stick to comments on the schematic you linked to at post #3, less confusing that way ?
You said the order is correct, hence BLK corresponds to GND.
The outer two pins of the connector are labelled with the colour of the wire that is used on many FTDI serial - USB cables, rather than the signal names that are used on the rest of the pins.
GRN = Green
BLK = Black
This is done to aid the user in connecting the connector in the correct orientation
One more question about checking joints,
in the case of desoldering or cutting the trace of the LED.
I did not manage to desolder it and I am worried to have touched with the hot iron other adjacent components.
In the end, I just managed to break the LED with a knife and the upper part slipped over.
The board seems still working without the LED.
do you have a figure of the Arduino pro mini I am using (see pic in post #1) with the definition of each surface component?
Could I check with a multimeter if I damaged any components?
