Alright, still relatively new to this, trying to write some modular code to operate an four-legged robot using eight servos.
Here is my code:
//forward and cw are positive
#include <Servo.h>
#define first_servo_pin 8
#define up 45
#define down 135
#define mid 90
#define pause 100
#define constant1 1
#define constant2 1
int original;
int epsilon = 3;
int vector;
int lookup1[4] = {1,1,1,1};
int lookup2[4] = {1,1,1,1};
int lookup3[4] = {1,1,1,1};
int lookup4[4] = {1,1,1,1};
int lookup5[4] = {1,1,1,1};
for(int i = 0; i < 4; i++) {
hip[i].attach(first_servo_pin+i);
hip[i].write(mid);
delay(pause);
for(int j = 0; j < 4; j++) {
knee[j].attach(first_servo_pin+4+j);
knee[j].write(down);
delay(pause);
translate(100);
rotate(90);
void moveLeg(tag,epsilon) {
original = hip[tag].read();
knee[tag].write(up);
delay(pause);
hip[tag].write(original + epsilon);
delay(pause);
knee[tag].write(down);
delay(pause);
void moveBody(unitVector) {
for(int i = 0; i < epsilon; i++) { //distance
for(int j = 0; j < 4; j++) { //four legs
moveLeg(lookup5(j),unitVector*epsilon);
void translate(vector) {
for(int i = 0; i < abs(vector)*constant1; i++) { //distance
for(int j = 0; j < 3; j=j+2) { //switch between sets
for(int k = 0; k < 2; k++) { //switch between legs
moveLeg(lookup1(j+k),2*epsilon);
moveBody(lookup2(j+k));
void rotate(angle) {
for(int i = 0; i < abs(angle)*constant2; i++) { //angle
moveLeg(lookup3(j+k),2*epsilon);
moveBody(lookup4(j+k));
Note - Most numbers are only placeholders and will be different in the final configuration.
… and here is my fault:
error: variable or field ‘moveLeg’ declared void In function ‘void setup()’:
In function ‘void loop()’:
At global scope:
Think I’m missing something fairly simple but I don’t have enough experience / practice to see it quickly. Any suggestions?
