hey guys,
I'm pretty new to this and have some basic questions...
I just need the simplest of arduino boards that could some run simple code (C++ ??) and from there: control 3 servo type motors.
The system is time dependent, so it should keep an internal clock, be able to set time without PC connection (2-3 buttons).
What type of board/chip should I get?
How will I program the board? (connect it to laptop so I can push the code in)
The servo/motors must be able to:
-keep rotating in the same direction indefinitely,
-be pretty strong ~35N of constant torque,
-don't need to be fast, just 5-25RPM @ ~35N constant torque
-not budge: hold position regardless of speed or external loads (~35N torque)
-hold speed: hold an exact fast or slow rotation regardless of random external loads (~35N torque)
-the arduino board should control and be aware of the exact servo position (=<1 degrees)
-servos CAN/SHOULD have external power, arduino just for control purposes
My question is: could you guys could get me some links for simple board/chip/supplies to get this done? point me in the right direction? I do have soldering equipment, basic electrical circuit and device knowledge, and C++ knowledge.
Thanks!!
