I am trying to get a project working using code taken from on line. The code is:
#include <Arduino.h> #include <Keyboard.h>
const int LEDPIN = 13; //LED connected to pin 13:
const int SENSORPIN = 3; //sensorpin connected to pin 3:
// variables will change:
int sensorState = 0, lastState = 0; // variable for reading the pushbuton status:
void setup () {
// initialize the LED pin as an output:
pinMode(LEDPIN, OUTPUT);
pinMode(SENSORPIN, INPUT);
digitalWrite(SENSORPIN, LOW); // turn on the pullup:
Serial.begin (9600);
void loop () {
//read the state of the pushbutton value:
sensorState = digitalRead(SENSORPIN);
//check if the sensor beam is broken
//if it is, the sensorState is HIGH:
if (sensorState == HIGH) {
//turn on led:
digitalWrite(LEDPIN, LOW);
else {
//turn off led:
digitalWrite(LEDPIN, HIGH);
if (sensorState && !lastState) {
Serial.println(“unbroken”);
if (!sensorState && lastState) {
Serial.println(“Broken”);
//begin keyboard communication:
Keyboard.begin();
delay(2000);
//send a keystroke:
Keyboard.write(‘s’);
//end keyboard communication:
Keyboard.end();
lastState = sensorState;
I am getting the following:
exit status 1
stray ‘\357’ in program
I know nothing about coding. Just trying to reproduce something that another individual has done. They know very little about coding and are not able to figure this out. Any assistance is greatly appreciated.
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn’t show the posting toolbar then you can just manually add the code tags: [code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
For some reason code copied from online occasionally contains hidden or non-standard characters that cause that error. When you post the code on the forum it strips out these characters. So if you copy and paste this code it should work for you:
void setup () {
void loop () {
//turn on led:
else {
//turn off led:
Serial.println("unbroken");
Serial.println("Broken");
Keyboard.begin();
delay(2000);
//send a keystroke:
Keyboard.write('s');
Keyboard.end();
Need some more assistance. In the above code, what is supposed to happen is when a photo sensor beam is broken, after a delay of 2 seconds, the Arduino is to tell the computer it’s connected to to type the letter S. I am trying to use this code to accomplish that but am not having success. The difference is I do not have the photo sensor hooked up. I am instead trying to trigger the S to be typed by sending 5 volts to pin 3. So far I have not been able to get this to work. I am unsure if pin 3 needs to be configured differently. I have been reading up on pin assignments but have not had any luck getting the info I need. Once again, any assistance is greatly appreciated. My plan is to take the 5VDC off the board, run it through a relay and return it to pin 3 on the board. The relay is being controlled by a PLC and will close for 200 ms. When that happens, I need the Arduino to tell the computer to type the letter S.
You say you're connecting 5V with a wire to pin 3. When the wire with 5V isn't connected, what is connected to pin 3? If you said nothing, then google "floating input" and learn about pull-up and pull-down resistors.
Thanks. That actually explained a lot. I'm familiar with working with PLC's but not these boards. May just go to the photosensors and keep the whole scoring system separate from my pinsetter control system. In case you wanted to see it, here is a link to what I've built: Half scale pinsetter running - YouTube
Thanks for the link with things in one nice package - I hope it is OK to ask about one of the circuits -
The Pull Down Resistor - is there and advantage / disadvantage or just don’t do it to adding a small cap across the 10k resistor?
Because of my industrial background I was always taught to use High to turn something on or hold something locked in - theory being if a wire broke things would stop or not turn on. Some years back someone had a go low to start something and a wire shorted to some conduit and a bridge section was activated and one person was killed - a bit obscure circuit but I am always cautious since much of the equipment I used to work on could seriously hurt someone if something went wrong.
I also have trouble with the thinking process of using low to start something in the code.
Just to add to what Delta_G said, (incidentally, she's well-versed and knows what she's talking about), after reading your posts - regardless of whether you're looking at a high or a low as being the active state, with CMOS input technology you can never be sure if an input will be high or low if left floating. It 'hovers' about the midpoint, and pretty well decides by luck on which way it will go. Unlike the earlier TTL circuitry, which will stay low unless a voltage or pullup resistor is applied to turn on the input transistor.
Oh no, what a blunder. I'm very sorry for that. I just assumed that your forum name was taken from Delta Goodrem's, and that you must have also been female.
(You know what they say about assuming. )
OldSteve:
No, my name comes from the symbol for the change in Gibbs free energy. I'm a chemist by trade.
allanhurst:
I seem to remember that standard TTL inputs were floating emitters of a NPN BJT with the base tied high, so if unterminated appeared as a 'high'
Allan
Oops, I was a bit rushed. I actually meant transistor inputs, not TTL. (I was referring to the base of a transistor.)
Have another question. Been googling but can’t fine the answer. I am getting a message “Keyboard’ not found. Does your sketch include the line ‘#include <Keyboard.h>’?” when I upload to my Arduino. I can not figure out why or how to fix this. Again, any help is greatly appreciated.
Post the latest version of your code. The last version I saw included that line and if it still does you shouldn't be getting that message. Also post the FULL error listing. Among other things it will tell you exactly where in the code the error occurs.
