Hello, i have a long-term experience with electronics, but mostly analog. I designed several Desk lamps, PSU and other house projects and i have only used a few digital components in my life, like flip flops and latches. I am trying to build a system to control the position of an axis from afar, for that i'll be using those 433Mhz AM modules and two arduinos that a friend got for me. But i am totally new to this and i have like 2 days to do it, it's pretty impossible to learn all this things in two days, so i decided to come to this forum and get some guidance on this matter. My idea was to use a pot, read it's value, positional value, transmit the data through the module, read it on the other arduino and then write this on the servo, i believe there are libraries to help me with this... I'm a fast learner. Also may i ask if there is a
way to make two ways of controlling the axis, one with the value from the pot and one that uses a predetermined way for it to spin, like, in 10s spin 180deg clockwise and then in 25 seg rotate 45deg anticlockwise... and you could switch between those 2
I was reading about users using VirtualWire with another Servo library so it does not conflict, can this be done with those libraries in a easy way ?
