New tube of atmega328-PU
I just got a tube of these the same numbers as the one in my real uno these are strait from microchip and the dang things show up with the wrong id.
So I change that from 0x0F to 0x14 burn bootloader all goes good till I try to use one.
They now show up as a 0x0F
I change avdude.conf back to the 0X0F and they now work fine. Has anyone had this happen.
The Uno has a atmega328-PU the new ones say the same thing crazy. Huh
The bootloader doesn't actually send the HW ID; it sends whatever the bootloader was built for.
The 0x14 ID is for a non-P ATmega328. If you ordered ATmega328P-PU but got ATmega328-PU, you should probably complain... (although they're nearly identical for Arduino purposes...)
That's what I been reading but these are not from ebay or some where there from mirochip the people who own AVR now.
This is before changing id
avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/burt/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
         User configuration file is "/home/burt/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 002:010
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9514 (probably m328)
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Error while burning bootloader.
I burn bootloader now it does this
avrdude: Device signature = 0x1e950f
avrdude: Expected signature for ATmega328P is 1E 95 14
I change it back to 0x0F and it works as it should.
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/tmp/arduino_build_973604/Blink.ino.hex"
avrdude: writing flash (928 bytes):
Writing | ################################################## | 100% 0.19s
avrdude: 928 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_973604/Blink.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_973604/Blink.ino.hex:
avrdude: input file /tmp/arduino_build_973604/Blink.ino.hex contains 928 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.15s
avrdude: verifying ...
avrdude: 928 bytes of flash verified
