I was attempting to troubleshoot board #1 (first Arduino Uno R3) by opening a new package containing another Arduino Uno R3 board (Board #2). Board #1 will accept programming, but board #2 will not accept programing, even the same program Board #1 accepted ("problem uploading board, see Arduino.cc....troubleshooting").
I have reviewed the trouble shooting guide, but did not find anything applicable. Again, when I plug in (usb) to board #1 everything works fine (for the most part). Not on board #2. Will not accept programming (simple programing) and gives an orange error message. Board #2 was in a sealed ESD package.
Uncheck the checkbox next to "Show verbose output during: compilation"
Check the checkbox next to "Show verbose output during: upload
Click "OK"
Sketch > Upload
After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the upload output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2888 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\billr\AppData\Local\Temp\arduino_build_801214/test.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\\.\COM4": The system cannot find the file specified.
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Neither option "upload" or " compilation" was checked when I first opened it. I checked "upload". Both boards appear to be identicial. Both were ordered from the same seller at the same time. Also, Port shows 'Com 3' while connected to Board #2, and 'Com 4' while connected to board #1, on the IDE drop down menu
