Apologies. I am a VERY new Raspbian on PI4 and Arduino user (2 days). The Raspbian is completely current. I downloaded the IDE and installed with SUDO from root. The IDE will not start at all. The installation error messages I received are pasted in from the console below.
pi@raspberrypi:~ $ sudo /home/pi/Applications/arduino-1.8.12/./install.sh
Adding desktop shortcut, menu item and file associations for Arduino IDE...
touch: cannot touch '/root/.config/mimeapps.list': No such file or directory
/usr/bin/xdg-mime: 848: /usr/bin/xdg-mime: cannot create /root/.config/mimeapps.list.new: Directory nonexistent
I uninstalled Arduino 1.8.12 and then downloaded and installed Arduino 1.8.10 and received the following (same) error in Console.
pi@raspberrypi:/ $ sudo /home/pi/Applications/arduino-1.8.10/install.sh
done!
pi@raspberrypi:/ $
Is it possible i need to completely re-install Raspbian?
after the above post I re-flashed Raspbian Full using my Mac. Then I tried to install 1.8.1, 18.7 and 1.8.12 with the same error messages. I have no idea what to do next!
I think the cause of this error is using the wrong version of the Arduino IDE. For Raspberry Pi, you need to use the version you get from the "Linux ARM 32 bits" link from the downloads page.
