The term "board descriptor file" is not one we ever use in the Arduino world. The code you're looking for is in the "variant" files.
Here's how you can find the variant file for any board:
The first thing you need to do is locate the board's platform folder. The easiest way to do that is as follows:
- Select a board from the hardware package you want to find from the Tools > Board menu
File > Examples > SPI > BarometricPressureSensor (or any other SPI example sketch)
- Sketch > Show Sketch Folder
- Move up folder levels until you reach the one that contains boards.txt
The next thing you need to do is find which variant your board uses. That is defined in boards.txt:
Open boards.txt in a text editor.
Find the section containing the configuration for the board you're interested in. For example, the Uno's section looks like this:
uno.name=Arduino Uno
uno.vid.0=0x2341
uno.pid.0=0x0043
uno.vid.1=0x2341
uno.pid.1=0x0001
uno.vid.2=0x2A03
uno.pid.2=0x0043
uno.vid.3=0x2341
uno.pid.3=0x0243
uno.upload.tool=avrdude
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.maximum_data_size=2048
uno.upload.speed=115200
uno.bootloader.tool=avrdude
uno.bootloader.low_fuses=0xFF
uno.bootloader.high_fuses=0xDE
uno.bootloader.extended_fuses=0xFD
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.bootloader.file=optiboot/optiboot_atmega328.hex
uno.build.mcu=atmega328p
uno.build.f_cpu=16000000L
uno.build.board=AVR_UNO
uno.build.core=arduino
uno.build.variant=standard
Find the build.variant property of the board. For the Uno it is here:
so you can see that the Uno uses the standard variant.
Now you need to find the variant. The variants are located under the variants subfolder of the platform folder. The variant name is defined by the folder name. So for the Uno you would look in the variants/standard folder.
The traditional location for the declarations of each variant is the pins_arduino.h file. That is where you would typically find the definition of LED_BUILTIN, etc. In some platforms, you will find that pins_arduino.h only contains this:
#include "variant.h"
and the declarations are located in variant.h instead.
The Nano and Pro Mini use the eightanaloginputs variant, but you'll find that that variant's pins_arduino.h file looks like this:
#include "../standard/pins_arduino.h"
#undef NUM_ANALOG_INPUTS
#define NUM_ANALOG_INPUTS 8
So you can see that the eightanaloginputs variant is identical to the standard variant, with the exception that the NUM_ANALOG_INPUTS macro is defined as 8 instead of 6.
In some 3rd party platforms, you might find something that looks like this:
someboard.build.variant:arduino:standard
This is using a cool feature that allows platforms to reference the variants of other platforms. So instead of the 3rd party platform needing to duplicate the variant code from another platform, it can just tell the Arduino IDE "get it from that other platform". More information on that here:
https://arduino.github.io/arduino-cli/platform-specification/#referencing-another-core-variant-or-tool
