NEW USER-help on stepper motor control programming
Hi All
I am working with my final year project and am a new user with the testing the stepper motor with L293D motor shield.
I have written the codes with “Arduino 1.0.5” and was stuck with the motor looping itself after 1 revolution (200 steps) and after delay (10000)
My intention was to only rotate forward 1 revolution and STOP.
Kindly advise any alteration to the codes
THX
COCO2014
#include <AFMotor.h>
// Connect a stepper motor with 48 steps per revolution (7.5 degree)
// to motor port #1 (M1 and M2)
AF_Stepper motor(48, 1);
Serial.begin(9600); // set up Serial library at 9600 bps
motor.setSpeed(20); // 20 rpm
motor.step(200, FORWARD, DOUBLE);
delay (10000);
If you literally only want it to make a single revolution and then stop the simplest thing is to move the 2 lines of code from loop() and put it into setup(). Actually there is then no need for the line with delay().
Leave loop() with nothing between the curly brackets.
...R
