new user trying to read and rewrite NFC tags for a 3D Printer
First of all hello, I am in the process of trying to get a program to work on my Arduino Uno using an Adafruit NFC Sheild in order to read and rewrite/write NFC tags for use with my XYZ Printing Da Vinci Junior 3D Printer, here is the program:
#include <PN532.h>
//This example reads all MIFARE memory block from 0x00 to 0x63. It is tested with a new MIFARE 1K cards. Uses default keys for authentication.
//Contributed by Seeed Technology Inc (www.seeedstudio.com)
#include <PN532.h>
#define SCK 13
#define MOSI 11
#define SS 10
#define MISO 12
PN532 nfc(SCK, MISO, MOSI, SS);
void setup(void) {
Serial.println("Hello!");
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata >> 24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata >> 16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata >> 8) & 0xFF, DEC);
Serial.print("Supports "); Serial.println(versiondata & 0xFF, HEX);
// configure board to read RFID tags and cards
nfc.SAMConfig();
void loop(void) {
uint32_t id;
// look for MiFare type cards
id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A);
if (id != 0)
Serial.print("Read card #");
Serial.println(id);
uint8_t keys[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; // default key of a fresh card
for (uint8_t blockn = 0; blockn < 64; blockn++) {
if (nfc.authenticateBlock(1, id , blockn, KEY_A, keys)) //authenticate block blockn
//if authentication successful
uint8_t block[16];
//read memory block blockn
if (nfc.readMemoryBlock(1, blockn, block))
//if read operation is successful
for (uint8_t i = 0; i < 16; i++)
//print memory block
Serial.print(block*, HEX);*
_ if (block <= 0xF) //Data arrangement / beautify_
* Serial.print(" ");*
* else*
* Serial.print("| Block ");*
* if (blockn <= 9) //Data arrangement / beautify*
* Serial.print(blockn, DEC);*
* Serial.print(" | ");*
* if (blockn == 0)*
* Serial.println("Manufacturer Block");*
* else*
* if (((blockn + 1) % 4) == 0)*
* Serial.println("Sector Trailer");*
* else*
* Serial.println("Data Block");*
* delay(2000);*
but i keep getting this error message:
Arduino: 1.7.9 (Windows 8.1), Board: "Arduino Uno"
In file included from readAllMemoryBlocks.ino:1:0:
C:\Users\MikeC\OneDrive\Documents\Arduino\libraries\PN532_SPI/PN532.h:8:22: fatal error: WProgram.h: No such file or directory
#include <WProgram.h>
compilation terminated.
Error compiling.
i have the file installed as
PN532.cpp (10.9 KB)
PN532.h (1.94 KB)
What file?
This
needs to be changed to
#include <Arduino.h>
recommended is what i meant to say and i have followed your suggestion and this is the new error
Arduino: 1.6.9 Hourly Build 2016/04/06 12:33 (Windows 10), Board: "Arduino/Genuino Uno"
GetFileAttributesEx C:\Users\MikeC\Desktop\3D Printer Files\Arduino\PN532_SPI\examples\readMifareMemory\readMifareMemory.pde: The system cannot find the file specified.
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
