New user
hello [u]everybody[/u],
Today i receved my new Arduino-one starter kit. So i tried the basic sample with the led on board.(Blink) That works oke, changing delaytime and so on. What i like to do is change the delaytime in the blink sample, with a potentiometer. Later i will try to change the led for a relay to deliver power for a solenoid.(12~24volts 2amp.)
Thanks, Piet.
Not too sure what you are asking. Do you want methods or code?
Read the pot and use the readings in the delay function.
Codes samples, everything what's helps. I will change the delay time.
Piet,
see it as a puzzle. For example search on http://arduino.cc/en/Tutorial/HomePage for the magic words "Analog Input". To make things easier, they're followed by: "use a potentiometer to control the blinking of an LED"
Korman
How about:- delay(analogRead(0)); as a starter in place of your simple delay.
It works, Thanks for helping.
