New version of irremote library and decode()
I have some problem with updating my project to library above version 2.8. I have spend a lot of time but I’m not able to solve a problem. I have wrote very simple code, that produce different output for different library version.
I think the new version of the library tries to decode some part of IR code as RC5 (2ACC, 2ABB values). Did anyone have such a problem?
I’m trying to decode Electrolux hob2hood protocol. The device send each command three times.
** The working code (the old one) and output:**
 #include <IRremote.h>
// IR Receiver PIN
const int PIN_IR_RECEIVER = 2;
IRrecv irrecv(PIN_IR_RECEIVER); // create instance of 'irrecv'
decode_results results;
  Serial.begin(115200); //change BAUD rate as required
  Serial.println("Hob2Hood Starting ...");
  Serial.println(" ... Setup IR receiver");
  irrecv.enableIRIn(); // Start the IR receiver
  Serial.println("Hob2Hood ready ...");
  if (irrecv.decode(&results)) {
    Serial.println("Received IR command: ");
    Serial.println(results.value, HEX); // display it on serial monitor in hexadecimal
    irrecv.resume();
The output:
55303A3
55303A3
55303A3
E208293C
E208293C
E208293C
E3C01BE2
E3C01BE2
E3C01BE2
D051C301
D051C301
C22FFFD7
C22FFFD7
C22FFFD7
B9121B29
B9121B29
55303A3
55303A3
55303A3
The not working code (the new one) and output:
// IR Receiver PIN
const int IR_RECEIVE_PIN = 2;
  pinMode(2,INPUT_PULLUP);
  IrReceiver.begin(IR_RECEIVE_PIN, DISABLE_LED_FEEDBACK);
  if (IrReceiver.decode()) {
    Serial.println(IrReceiver.decodedIRData.decodedRawData, HEX); // display it on serial monitor in hexadecimal
    IrReceiver.resume();
E208293C
E208293C
E208293C
E3C01BE2
2AB5
E3C01BE2
D051C301
D051C301
D051C301
C22FFFD7
C22FFFD7
C22FFFD7
B9121B29
2AAC
2AAC
55303A3
2AAB
55303A3
