avrgen:
So this nice kind of visualization is something like your life work?
So it seems...
avrgen:
So it seems...
Dear mitov,
I'm very attracted by such these visual tools and today i downloaded the demo f visuino (this name is very similar to my surname....).
It's very interesting and i was thinking to buy a copy of it, but...
I tried to realize a very simple circuit in which a button lights a led. I press and release the button and the led remains active.
The source code is easy. It's only an if operation.
But in Visuino the tutorial makes me add an edge detector and a T flip flop. Is there the possibility to have blocks more similar to the real instructions?
Thank you very much and best regards
Bruno
brvus:
Hi Bruno,
Thank you!
The Visuino uses a completely different concept than programming. There is no IF statement as there are no statements at all. It uses a data-flow programming and, the design is completely different than coding. That is why the diagram looks different, and is actually easier to follow IMHO
With best regards,
Boian
Hello everyone,
It has been a while since I have been in the forum, and a lot has been happening in the Visuino development.
Earlier this year I redesigned it to generate over 90% less code and the generated code to use over 90% less RAM.
Redesigned the IDE to work faster.
I have also improved significantly the graphics display, and NeoPixels support, added large number of new platforms including ESP32, micro:bit, Maple Mini and more.
Introduced the Visuino Pro as a Beta with full Modbus support.
Added support for a number of robot shields and platforms.
Included live help, easier updates, and added hundreds of modules and new components.
I even added option to inject custom code in the Visuino project making it easier to access components currently not supported in Visuino.
Now, I just released Visuino - Graphical Development for Arduino - 7_8_2_259 with YahBoom BBC micro:bit robot support
Added YahBoom BBC micro:bit robot support
Improved BBC micro:bit support
Improved NeoPixels support for ESP32
Reduced Memory Usage by most Motor Control components
Reduced Memory Usage by the WiFi, Ethernet, and GPRS components
Reduced memory usage by SPI SSD1306 Display
Improved ST7735 Display implementation with reduced memory usage
Improved PCA9685 PWM implementation
Improved RGBW Ramp To Color component
A numbed of Visuino IDE improvements
Updated version of the User Code Component is included in the Visuino Pro version available in the G+ Community
https://plus.google.com/communities/116125623808250792822
Cheers,
Boian
Hey, Mitov. This is super cool and I'm eager to try it out.
I have a suggestion which is to encourage you to port the program to Linux. I think it might have good pick-up by Raspberry Pi users and I'm planning to run the Linux side-load (or whatever) on my Chromebook.
That's just my two cents. Thanks a lot and I'm glad to see that development is still on-going!
J
jkwalker111:
Thank you!
Working on MAC and Linux port, but since I am the only guy developing it, and I am already overloaded adding all the new modules and boards, not to mention the rest of my products, it takes time... .
Just released Visuino - Graphical Development for Arduino - 7_8_2_261 with Elegoo PenguinBot robot support and more...
Added support for SparkFun ESP32 Thing
Added support for Elegoo Penguin Bot
Added support for stm32duino STM32F103C8 Blue Pill
Added support for SSD1331 Color OLED Display
Added support for Macetech RGB Shades
Added support for Maiyout Serial MP3 Player (MY1690-12P/MY1690-16S)
Added categorized selection for cotroller boards
Added Filtering for component elements
Improved Graphics Performance
Reduced memory usage and improved speed by many of the graphics displays
Improved Circuit Playground support
Improved ESP32 BPI-bit support
Improved support for the YahBoom Robot
Improved EVIVE Support
Improved performance by some of the components
Improved Motor Drivers Components
Improved PL uino support
Improved Nextion Display support
Cheers,
Boian
Just released Visuino - Graphical Development for Arduino - 7_8_2_290 with Elegoo Balancing Robot support and more...
Cheers,
Boian
Mitov,
Good morning!
Wich is your contact ? I would like to test the VISUINO with NINA W102 and NINA B112, but i have some questions and bugs to report!
I am sure that the Brazilians will love VISUINO with U-BLOX MODULES. I am support in BRAZIL
Miguel
basic4ever:
Miguel
Thank you! My e-mail is mitov@mitov.com . For the last 2 months + I have been working on a brand new Visuino version that uses completely redesigned code generation and with some advanced C++ techniques generates extremely small memory usage code. It is designed to generate code that uses less memory than code written by even very experienced developer, doing a lot of memory optimization tricks. This has been taking all of my time, and I have fallen behind on some e-mails and other stuff, but this push is almost over now, so I will be able to focus on other items again
Just released Visuino - Graphical Development for Arduino - 7_8_3_3 with initial Raspberry Pi, ESPCopter, Arduino Every, M5 Stack Core support and more...
https://www.visuino.com/download
Updated version of the User Code Component is included in the Visuino Pro version available in the MeWe Community
Here is also the updated Component Development SDK:
I hope you will enjoy all the new features, and the new completely free mode
Cheers,
Boian
Just released Visuino - Graphical Development for Arduino - 7_8_3_9 with VL53L0X Laser Ranger support and more...
Morning
I really like this software , and am running the trail for now , but i am battling to run really simple functions . I also can't find any examples , to do very basic projects . I can write the code very easily but to do the same in Visuino I can't seem to bridge the gap . Example , I have 3 led`s representing a traffic light , switching them on and off with time delays in between and then repeating the loop . I would like to learn the use of the software the same way i learnt how to code manually , but i am battling to bring the one to the other .
Some help would really be appreciated .
Thanks
Herman
herman3030:
Hello Herman,
Thank you! There are a lot of demos included with the Install . You can select |File|Open Demo...| from the menu.
For traffic light you can use the Sequence component and add 3 digital periods controlling the 3 LEDs
You can add multiple sequences and they will work independent from each other and you can control multiple traffic light with different timings simultaneously, something not that simple in traditional programming
Cheers,
Boian
Thanks a lot it works very simple , I would have never got there on my own , I am just battling to think in the way i would code it , and then apply it using Visuino , but i will work thru the demos and apply it in my tinkering.
Thanks alot
Herman
herman3030:
You are Welcome! I hope you will enjoy it
Cheers,
Boian
Just released version 7_8_3_14 with expanded M5Stack support and more...
Just released Visuino - Graphical Development for Arduino - 7_8_3_16 with expanded M5Stack support and more...
Brand new revolutionary code generation design producing extremely efficient low Flash/ROM and especially RAM usage - up to 90% less RAM usage by the generated code, and up to 60 % less Flash/ROM usage
Up to 90% execution speed improvement by the generated code
A Completely Free Mode of Visuino now available for entry level users and students
Added KocoaFab Orange Board BLE support
Added TM1637 and TM1638 support
Improved SeeedStudio Grove System support
Added BMM150 support
Added PCA9554 support
Added SeeedStudio Grove System Generic Digital and Analog Input components
Added SeeedStudio Grove System Generic Digital Output component
Added SeeedStudio Grove System Relay, Button, and Touch components
Added M5Stack Dual Button Unit component
Added M5Stack Joystick Unit component
Added M5Stack PIR Motion Sensor Unit component
Added M5Stack StickC Environment Hat
Just released Visuino - Graphical Development for Arduino - 7_8_3_20 with expanded M5Stack, SeeedStudio Grove System support and more...
Just released Visuino and Visuino Pro - Graphical Development for Arduino - 7_8_3_58 with new builtin Compilation, Upload, Boards and Libraries management and much more...
This is a really big release, and allows directly to compile and upload code without the need to open the Arduino IDE!
Here is what's new:
The Visuino Pro and the Visuino SDK are also both available for download on the Visuino site:
