New wind chime art installation / instrument with machine learning.
Hi all,
I’m currently re-opening an art installation project first discussed on this forum here:
https://forum.arduino.cc/?topic=671727#msg4799676
I've added a simple photoresistor on the top, which can manipulate the sound as you move your hand closer to it, it sounds as if I've added a theremin to it. I've also added a DHT11 temp/humidity sensor which means in theory I could make it so the wind chime sounds different in different environments and different time of the day.
I've also discovered a piece of software called Wekinator which is an easy to use machine learning platform for artists and musicians making similar projects - which should hopefully stabalise the randomness and unpredictability that was the main pitfall of the last project.
I'm re-familiarising myself with the Arduino after a six month break so I'm slowly starting to understand things again however I'm struggling to get the new elements to work alongside the piezo system I had already created. I'll link the simple tutorials I used for the DHT11 and photoresitor:
[u]https://arduinogetstarted.com/tutorials/arduino-light-sensor[/u]
[u]https://create.arduino.cc/projecthub/techno_z/dht11-temperature-humidity-sensor-98b03b[/u]
I've managed to get the DHT11 to work with the piezo code but adding the photoresistor ruined the piezo readings somehow which is bizarre because I thought that would be the easy part. I can get each element to work individually but together something goes wrong. I've certainly messed up the code. My feeling is that it's to do with the delay times it takes for each element to process information. If anyone can point me in the right direction that would be great.
#include "DHT.h"
#define DHTPIN 3
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
const byte nSensors = 5; //here is the code from last time - I added another to make it 6 for resistor
const byte nSamples = 100;
const byte piezoPin[nSensors] = {A0, A1, A2, A3, A4, A5}; //A5 is the photoresistor, others are piezo
int piezoValue[nSensors]; // No need to initialise here.
int finalValue[nSensors];
  analogReference(INTERNAL); // remove this line if too sensitive
  dht.begin();
  piezo();
  delay(250); //here I've pasted in the code from the dht11
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print(h); // I only wanted the humidity, temp in Celsius and heat index
  Serial.print(F(" "));
  Serial.print(t);
  Serial.println(hic);
void piezo() { // and here starts the piezo code from original project
  for (int i = 0; i < nSensors; i++) { // By convention the i is used as loop iterator.
    for (int j = 0; j < nSamples; j++) { // Need more? Continue with the alphabet.
      int rawValue = analogRead(piezoPin[i]); // 100 A/D readings
      if (rawValue > piezoValue[i]) {
        piezoValue[i] = rawValue; // store peaks
    if (finalValue[i] < piezoValue[i]) { // fast attack
      finalValue[i] = piezoValue[i];
    else {
      finalValue[i] = (finalValue[i]) / 50; // smooth decay
    piezoValue[i] = 0; // reset
    Serial.print(finalValue[i]);
    Serial.println(F(" "));
I'm somewhat confused. What number are you actually using for nSensors in the program which fails? 5 or 6?
Can you please explain more precisely what happens when you run the program. How are the piezo readings "ruined"? What is the "something goes wrong"?
Hi thanks for the reply, and sorry for being slow to get back myself!
Since I first posted this I've made some progress with the code and I've managed to fix the problem. I'll paste the code below. If you have any suggestions how I can make it more efficient I'd be very grateful. Thanks again
#include "DHT.h"
#define DHTPIN 3
const byte piezoPin[nSensors] = {A0, A1, A2, A3, A4};
  dht.begin();
  int analogValue = analogRead(A5);
  piezo();
  if (isnan(h) || isnan(t)) {
    return;
  Serial.print(h);
  Serial.print(t);
  Serial.print(analogValue);
void piezo() {
    else {
