Allow me to announce my new X9C library, available here
It is - IMHO - much easier to use for simple cases than existing libraries, and is fully functional on ESP8266
For the simplest case, only two calls are required:
begin(CS,INC,UD) // to define the h/w pins used
and
setPot(value, save); // to set percentage value and save= true or flase to save the value in NVRAM
the full example code showing how easy it is:
#include <X9C.h>
#define INC 2 // D1 Mini D4 - pulled up in H/W (10k) -> chip pin 1
#define UD 15 // D1 Mini D8 -> chip pin 2
#define CS 16 // D1 Mini D0 - pulled up in H/W (10k) -> chip pin 7
// "up" and "down" make sense in relation to the wiper pin 5 [VW/RW] and the HIGH end of the pot
// i.e. pin 3 [VH/RH], leaving pin 6 [VL/RL] unused (floating). You can easily use pin 6 instead
// pin 3, but "min" will actually mean "max" and vice versa. Also, the "setPot" percentage will
// set the equivalent of 100-<value>, i.e. setPot(70) will set the resistance between pins 5 and 6
// to 30% of the maximum. (Of course in that case,the "unused" resistance between 5 and 3 will be 70%)
// Nothing to stop you using it as a full centre-tap potentiometer, the above example giving
// pin 3[H] -- 70% -- pin 5[W] -- 30% -- pin 6[L]
X9C pot; // create a pot controller
pot.begin(CS,INC,UD);
pot.setPot(44,true); // true=save, so pot will be about 44% max value after shutdown if you do nothing else...
pot.setPotMin(false); // don't save set to 0% max - actually 200R-300R on my samples
pot.trimPot(10,X9C_UP,false); // temporarily about 10% max value
pot.trimPot(3,X9C_DOWN,false); // pot will now be at about 7% (+10-3) max value
// because none of the above "tweaks" saved their value, you should find pot set at about 44% after shutdown
// and of course, next time you run the sketch.
Any feedback welcomed
