Newb Here! Tons of questions
First off, hello all, im new here.
All questions are on Ubuntu 8.10
  1. Error Building libary “Stepper”
  2. Will this code be correct to just make a servo move to test it?
// Sweep
// by BARRAGAN <HIS SITE HERE>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
  myservo.attach(0);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
(1) What IS the error you got when you tried to build the “Stepper” library? How did you attempt to build the library?
(2) myservo.attach(0); // attaches the servo on pin 9 to the servo objects
Attaching things to pin 0 will make it hard to use the serial port, and I think the default library only supports pins 9 and 10.
That is my old code, I changed it to 9. Also I didn't do anything. I opened up the program for the first time, put the code in and attempted to add that servo code to my microcontroller and got the stepper error.
