Hi all
i am not a pro in programming but i have a small question.
for my project i need to blink one led.
to make it easy 1000ms on, 1000ms off
now i need to run a second code simultaneously
lets say a 6 led pattern switching every 1500ms
in a usual loop in can let one led blink every second.
if i use delay (like the blink sketch) i cant run a second loop
how can i keep one led blinking while executing a second loop
with kind regards
Robbert Loos
J-M-L
October 23, 2016, 9:54pm
2
There are many ways to do what you want.
If this is a personal project here's something to learn from.
If it's homework don't turn in the following unless you can explain how it works!
#define NUM_ENTRIES(ARRAY) (sizeof(ARRAY) / sizeof(ARRAY[0]))
const uint8_t pinLED = 13;
const uint8_t pinLED_1 = 33;
const uint8_t pinLED_2 = 32;
const uint8_t pinLED_3 = 31;
const uint8_t pinLED_4 = 30;
const uint8_t pinLED_5 = 29;
const uint8_t LED_OFF = LOW;
const uint8_t LED_ON = HIGH;
const unsigned long HALF_SECOND = 500UL;
const unsigned long ONE_SECOND = 1000UL;
const uint8_t pinsLEDS[] = { pinLED_1, pinLED_2, pinLED_3, pinLED_4, pinLED_5 };
class timerT
bool m_triggered;
unsigned long m_tmsTarget;
public:
timerT(unsigned long tms) : m_triggered(false), m_tmsTarget(millis() + tms)
bool has_expired()
if ( ! m_triggered )
m_triggered = ((long)(millis() - m_tmsTarget) >= 0);
return m_triggered;
pinMode(pinLED, OUTPUT);
digitalWrite(pinLED, LED_ON);
for ( size_t i = NUM_ENTRIES(pinsLEDS); i--; )
pinMode(pinsLEDS[i], OUTPUT);
// ... BLINK SINGLE LED ...
static timerT timerLED(ONE_SECOND);
if ( timerLED.has_expired() )
timerLED = timerT(ONE_SECOND);
digitalWrite(pinLED, !digitalRead(pinLED));
// ... SEQUENCE 5 LEDS ...
static timerT timerLEDS = timerT(HALF_SECOND);
static size_t iLED = NUM_ENTRIES(pinsLEDS) - 1;
if ( timerLEDS.has_expired() )
digitalWrite(pinsLEDS[i], LED_OFF);
iLED = (iLED + 1) % NUM_ENTRIES(pinsLEDS);
digitalWrite(pinsLEDS[iLED], LED_ON);
J-M-L
October 24, 2016, 4:47am
4
@lloyddean
Your code is at risk with wrapping millls() and unsigned long
Would suggest
timerT(unsigned long tms) : m_triggered(false), m_tmsTarget(millis())
m_triggered = (millis() - m_tmsTarget) >= tms;
Instead
thank you very much, really appreciate the info, gonna study tonight
Thanks for the catch, I pulled it from a 8 year demo I did.
