Newbe question about programming
Hi all, I am new to programming. I do have a sketch that does work. I am trying to tweak it to what I want versus writing a new one at this time. This is the section of my sketch I have questions about. One of my lines reads:
int bluemax = 225 ; //maximum dimming value of blue led's range 0-255
Can I just change the value to say 0-18 and also make the change in the int bluepercent line? What I am trying to due is fade my lights in but i do not keep them on high. The way it is set up now, the display will read 0 thru 10. Would I have to change the percent values also? I just need pointed in the right direction. Thanks, Jim
Hi and welcome to the forum.
When asking for help on a sketch, it is almost always more helpful to post all of the code and not just the small section you are asking questions about.
In fact, your question even breaks down because you reference a line with "int bluepercent". It is kind of tough answer your question since there is no other context.
(Also, when posting code, wrap it in code tags. Highlight the pasted code and click the "#" button in the editor.)
I guess your talking about the code from here. and there are variables defined as min and max, so yes you can just change those.
A value of 255 = 100% 127= 50% and so on.
To fade in the opposite direction have you tried swapping the min and max values? We would need to see the code to really understand what is going on.
Why areyou even asking this. Try it and if it dosen't do what you expect then ask about it.
I am sorry Mike, I thought this part of the forum was for asking questions? As I stated I just wanted to be pointed in the right direction, I was not looking for anyone to fix it for me. Smile and have a nice day.
It is. But there are some things that are better learned by trying. Change the value from 255 to some other value, and observe the results. That will mean a lot more than us telling you what will happen.
Ok, I did change the values and it does compile so that’s good. I will try uploading and check the results. The only way at this time would be by checking output voltage due to the fact, my tank relies on this light.
my tank
Fish, septic or main battle?
A salt water tank.
, I did change the values and it does compile so that's good.
OK here is another tip. Just because something compiles does not mean it will do what you want or even run like you think. It means you have not made an overwhelmingly big cock up with the syntax. It is just that the compiler managed to translate what you put into machine code.
The fact that it compiles is just a starting point and nothing to congratulate yourself about. The most stupid programs in the world can compile.
Win7 is a good example.
i am using the one that is with the arduino program. Is that one okay?
The one what? Which of the 14 versions of the "arduino program" are you using?
Arduino 0023 . Will this one work? By the way I did try running the program and the results wern't what I expected. Back to the drawing board.
and still you haven’t posted your code.
just an observation. :slight_smile:
@rjhudak1
I am curious, can you post you code, if you don’t mind ? Maybe your program could be of use for me. I may integrated in one of my program. Just click the → # <— and “Copy & Paste” your code.
Copy the code in your IDE and Paste your code here
What were the results? What had you expected?
Our psychic quit last week, with no notice. We're struggling the best we can until we hire another one. Help us out, in the mean time.
Here is the first part of the code.
originally written by Christian, cptbjorn@gmail.com
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68 //set rtc
#include <LiquidCrystal.h> // initialize the library with the numbers of the interface pins
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  R E L A Y   P A R T  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  S I M P L E   O N   A N D   O F F   F E A T U R E |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
const int ledPin1 =  2;          // pin number for relay 1
const int ledPin2 =  8;          // pin number for relay 2
int ledState1 = LOW;
int ledState2 = LOW;
long previousMillis1 = 0;
long previousMillis2 = 0;
long interval1 = 30000;          // interval at which to blink (milliseconds) for RELAY1
long interval2 = 50000;		 // interval at which to blink (milliseconds) for RELAY2
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L E D   D I M M I N G   P A R T  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  F A D E S   I N   A N D   O U T  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
int blueramptime = 60 ;    // time for blue LEDs to dim on and off in minutes
int whiteramptime = 180 ;  // time for white LEDs to dim on and off in minutes
int bluemin = 0 ;          // minimmum dimming value of blue LEDs, range of 0-255
int bluemax = 255 ;        // maximum dimming value of blue LEDs, range of 0-255
int whitemin = 0 ;         // minimum dimming value of white LEDs, range of 0-255
int whitemax = 255 ;       // maximum dimming value of white LEDs, range of 0-255
int photoperiod = 300 ;    // amount of time array is on at full power in minutes
int ontime = 10 ;          // time of day (hour, 24h clock) to begin photoperiod fade in
int blue = 3;              // blue LEDs connected to digital pin 3 (pwm)
int white = 11;            // white LEDs connected to digital pin 11 (pwm)
int bluepercent[11] = { 0, 1, 2, 5, 8 ,12, 18, 27, 44, 80, 255 };   // this line is needed if you are using meanwell ELN60-48D
int whitepercent[11] = { 0, 1, 2, 5, 8 ,12, 18, 27, 44, 80, 255 };   // these are the values in 10% increments
//int bluepercent[11] = { 0, 26, 52, 78, 103, 128, 154, 180, 205, 230, 255 };   // this line is needed if you are using meanwell ELN60-48P
//int whitepercent[11] = { 0, 26, 52, 78, 103, 128, 154, 180, 205, 230, 255 };   // these are the values in 10% increments
// int pwm_one = 10;       // extra pwm pin for future use
// int pwm_one = 9;        // extra pwm pin for future use
LiquidCrystal lcd(12, 13, 4, 5, 6, 7);   // typically 8, 9, 4, 5, 6, 7
                                         // have to change to free up more pwm pins
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  R T C   C L O C K   D S 1 3 0 7  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
byte decToBcd(byte val)    // Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)    // Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
  Wire.beginTransmission(DS1307_I2C_ADDRESS);
  Wire.send(0);
  Wire.send(decToBcd(second)); // 0 to bit 7 starts the clock
  Wire.send(decToBcd(minute));
  Wire.send(decToBcd(hour));   // If you want 12 hour am/pm you need to set
  // bit 6 (also need to change readDateDs1307)
  Wire.send(decToBcd(dayOfWeek));
  Wire.send(decToBcd(dayOfMonth));
  Wire.send(decToBcd(month));
  Wire.send(decToBcd(year));
  Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  // Reset the register pointer
  Wire.send(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  // A few of these need masks because certain bits are control bits
  *second = bcdToDec(Wire.receive() & 0x7f);
  *minute = bcdToDec(Wire.receive());
  *hour = bcdToDec(Wire.receive() & 0x3f); // Need to change this if 12 hour am/pm
  *dayOfWeek = bcdToDec(Wire.receive());
  *dayOfMonth = bcdToDec(Wire.receive());
  *month = bcdToDec(Wire.receive());
  *year = bcdToDec(Wire.receive());
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  D E F I N E  :  O N E S E C O N D |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void onesecond() //function that runs once per second while program is running
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
  lcd.setCursor(0, 0);
  if(hour>0)
    if(hour<=12)
      lcd.print(hour, DEC);
      lcd.print(hour-12, DEC);
    lcd.print("12");
  lcd.print(":");
  if (minute < 10) {
    lcd.print("0");
  lcd.print(minute, DEC);
  lcd.print(":");
  if (second < 10) {
    lcd.print("0");
  lcd.print(second, DEC);
  if(hour<12)
    lcd.print("am");
    lcd.print("pm");
  lcd.print(" ");
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  D E F I N E  :  R E L A Y 1 |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void relay1()  //FUNCTION TO TURN ON AND OFF RELAY 1.
  if(currentMillis - previousMillis1 > interval1)
    previousMillis1 = currentMillis;
    if (ledState1 == LOW)
      ledState1 = HIGH;
      ledState1 = LOW;
    digitalWrite(ledPin1, ledState1);
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  D E F I N E  :  R E L A Y 2 |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void relay2()
  unsigned long currentMillis2 = millis();
  if(currentMillis2 - previousMillis2 > interval2)
    previousMillis2 = currentMillis2;
    if (ledState2 == LOW)
      ledState2 = HIGH;
      ledState2 = LOW;
    digitalWrite(ledPin2, ledState2);
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  S E T U P  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
  pinMode(ledPin1, OUTPUT);    // set the digital pin as output:
  pinMode(ledPin2, OUTPUT);    // set the digital pin as output:
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  S E T U P - D I S P L A Y |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
  Wire.begin();
  // Change these values to what you want to set your clock to.
  // You probably only want to set your clock once and then remove
  // the setDateDs1307 call.
  second = 10;
  minute = 31;
  hour = 15;
  dayOfWeek = 6;  // Sunday is 0
  dayOfMonth = 12;
  month =5;
  year = 11;
// setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
  analogWrite(blue, bluemin);
  analogWrite(white, whitemin);
  lcd.begin(16, 2); // set up the LCD's number of rows and columns:
  //  lcd.print("12:00 80.6"); // Print a message to the LCD.
  //  lcd.print(char(223));
  lcd.setCursor(0, 1);
  lcd.print("blue:");
  lcd.print(33*bluemin/85);
  lcd.setCursor(8, 1);
  lcd.print("white:");
  lcd.print(33*whitemin/85);
The second part. What I wanted to do was only ramp up 50 to 60% with the abilities to change and change the relays to on and off at certain times. I also will be adding a temp probe and a salinity probe to this build. Thanks for any input.
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
  onesecond();
  relay2();
  relay1();
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - D I M   F U N C T I O N |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
  int daybyminute = ((hour * 60) + minute); //converts time of day to a single value in minutes
  int bluerampup;
     if (daybyminute >= (ontime*60))
       bluerampup = (((ontime*60) + blueramptime) - daybyminute);
       bluerampup = blueramptime;
  int whiterampup;
    if (daybyminute >= (ontime*60 + blueramptime))
       whiterampup = (((ontime*60) + blueramptime + whiteramptime) - daybyminute);
       whiterampup = whiteramptime;
  int whiterampdown;
    if (((ontime * 60) + photoperiod + blueramptime + whiteramptime) <= daybyminute)
      whiterampdown = (((ontime*60) + photoperiod + blueramptime + 2*whiteramptime) - daybyminute);
      whiterampdown = whiteramptime;
  int bluerampdown;
    if (((ontime * 60) + photoperiod + blueramptime + 2*whiteramptime) <= daybyminute)
      bluerampdown = (((ontime*60) + photoperiod + 2*blueramptime + 2*whiteramptime) - daybyminute);
      bluerampdown = blueramptime;
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - F A D E  I N |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
    if (daybyminute <= ((ontime*60) + blueramptime + (whiteramptime/10*9))) //if time is in range of fade in, start fading in + (whiteramptime/10*9)
      // fade blue LEDs in from min to max.
      for (int i = 1; i <= 10; i++) // setting ib value for 10% increment. Start with 0%
        analogWrite(blue, bluepercent[i]);
        lcd.setCursor(5, 1);
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((bluerampup*60)/10); // calculates seconds to next step
        while (countdown>0)
          onesecond(); // updates clock once per second
          countdown--;
          relay2();
          relay1();
      // fade white LEDs in from min to max.
      for (int i = 1; i <= 10; i++) // setting i value for 10% increment. Start with 0%
        analogWrite(white, whitepercent[i]);
        lcd.setCursor(14, 1);
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((whiterampup*60)/10); // calculates seconds to next step
        while (countdown>0)
          countdown--;
          relay2();
          relay1();
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - M A X  V A L U E |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
 if (daybyminute >= ((ontime * 60) + blueramptime + whiteramptime))
    if ( daybyminute < ((ontime * 60) + blueramptime + whiteramptime + photoperiod)) // if time is in range of photoperiod, turn lights on to maximum fade value
      analogWrite(blue, 255);
        lcd.print(10);
        lcd.print(" ");
      analogWrite(white, 255);
        lcd.print(10);
        lcd.print(" ");
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - F A D E  O U T |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
    if (((ontime * 60) + photoperiod + whiteramptime + 2*blueramptime + (blueramptime/10*9)) >= daybyminute)
      // fade white LEDs out from max to min in increments of 1 point:
      for (int i = 10; i >= 0; i--) // setting i value for 10% increment. Start with 10%
        lcd.print(10);
        lcd.print(" ");
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((whiterampdown*60)/10); // calculates seconds to next step
        while (countdown>0)
          countdown--;
          relay2();
          relay1();
      // fade blue LEDs out from max to min in increments of 1 point:
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((bluerampdown*60)/10); // calculates seconds to next step
        while (countdown>0)
          countdown--;
          relay2();
          relay1();
}  // END LOOP
OK. That's what you wanted. Now, you still haven't answered the questions I asked. What did you expect to happen? What actually happened?
