Forum, I've reading, and reviewing forums, tutorials for over 2 weeks now to see if I can tackle an ambitious project. I want to install multiple 2 channel music spectrums in my vehicle. I am flexible on the setup. I want install at a minimum 2 spectrums, possible 3(1 Spectrum with Strips- 2 channels, 1 with LED's- 2 channels and 1 with a small matrix 2 channel - 7 Bands) So 3 locations in the vehicle. I am gonna take a guess I would suspect I need at least 6 Arduino's and 6 music shields. I will need to use a Mosfet approach to power the setup. I will use the Bliptronics music shields.
I have some questions.
Since the 3 spectrum's with have the same frequency sequences on each channel, is it possible to run(process\power) the 3 locations off 1 Arduino and 1 shield and mofsets? What is the wiring and power wiring approach?
Also is it possible to run another application simultaneously for different set of LED's to do something anything unrelated to music. Or would I have to use a separate Arduino for that? Or can the program the Arduino process different set off LED's for different purposes.
I have other things in mind as I stated this is an ambitious project. I do have a background in coding for many years and I think that will help with coding once master the reference of the code with the hardware. Any comments, whether favorable or critical is appreciated. I excited about this project and have always been fascinated with LED's and have been looking for a hobby to get experience in as I head toward later part of my life. Well, I put it out there. I respectfully look forward to your comments.
DAB
