Newbee: Reading multiple sensors; read in the loop or attachInterrupt()?
Hi, I'm just getting started with Arduino. I have a an arduino Uno that I want to use to read from 8 sensors. The sensors are flow meters and output a pulse signal. I have a test working with one sensor.
Here is my test code:
static int siPulseCounter=0;                       //Variable keeping track of pulse counts
static int siSecondCount=0;                        //Variable keeping track no. of seconds in the timer1 block
void SetupTimer1()                                //Setting up timer1 with appropriate register values
      TCCR1A = 0;                                 // No PWM is used.So set this to zero.
      TCCR1B = 1<<CS12 | 0<<CS11 | 0<<CS10;       // Input clock is set to F(cpu)/256
      TIMSK1 = 1<<TOIE1;                          // Enable timer interrupt to detect overflow
      Set the timer count to overflow to in 1 second.
      My board has a 16MHz oscillator.
      Reload Timer Value  = ((2 ^ Bits) - 1) - ((Input Frequency / Prescale) / Target Frequency)
                          = 65535 - ((16 x 10 ^6 Hz)/256)/1 Hz
                          = 65535 - 62500
                          = 3035
      TCNT1=0x0bdb;                               //3035 in hex
ISR(TIMER1_OVF_vect)                             // Timer1 ISR when it overflows
    TCNT1=0x0bdb;                                //Reset Timer1 to count another second
    siSecondCount++;                             //Increase second count
    if(siSecondCount>=1)                        //If 60 Seconds are attained Print the Pulse count to serial port.
        Serial.print("Pulse Count is ");
        Serial.print(siPulseCounter,DEC);    	//Print as decimal value
        Serial.print("\n");
        siPulseCounter=0;                       //Reset counter values for next minute cycle
        siSecondCount=0;
void setup(void)
      pinMode(iPulsePin, INPUT);                  // Set Pulsepin to accept inputs
      digitalWrite(iPulsePin, LOW);
      attachInterrupt(0, count, RISING);          // Caputres external interrupt 0  at iPulsepin at rising edge and calls funtion count defined below
      Serial.begin(9600);                         // Begin Serial communication at baudrate 9600 bps
      SetupTimer1();                              // Call Setuptimer1 function
      Serial.println(" Initialising, Please wait...");
void loop(void)
void count()                                    // Function called by AttachInterrupt at interrupt at int 0
      siPulseCounter++;                        //increment the pulse count
This is working fine and providing the pulses counted for the last hour.
I am using attachInterupt but now realise that the Uno only has 2 external interrupts.
Could this just be done in the loop, so each time it loops it checks to see which of the 8 inputs are high, then increment a counter for that sensor or could it possibly miss a pulse?
Tom
This might be interesting for you - Arduino Playground - PinChangeInt -
you can read multiple ports at once.
