Newbie Advice
I’m new to arduino, but I have used Picaxe for some of my projects in the past. My interest is building models from the Star Wars films. There is a small robot in the 1st movie known as the “mouse droid” which I thought would make a great project for me to incorporate arduino. Based on this here is what I would like to try and accomplish:
-The original “robot” from the film was built over an R/C car which is what I would like to use as a base. Can I use a standard R/C motor with the Arduino? Can I control direction of the front wheels with a servo?
-I want it to operate like a Roomba ( for lack of a better example) that would roam a space and avoid walls and obstacles.
-I want to be able to control speed.
-I would like it to play sound effects.
-I would like to replicate the film so if it “hears” a loud sound it will play a certain sound effect then turn away from it.
-I would also like to control it from an iphone manually at times.
My best guess would be I need:
Arduino UNO R3 board with DIP ATmega328P
Arduino Motor Shield R3
SainSmart HC-SR04 Ranging Detector Mod Distance Sensor (Blue)
Kootek® BT2S Bluetooth to Serial Slave RS232 TTL UART Module Board for Arduino
LM393 Sound Detection Sensor Module Sound Sensor Intelligent Vehicle For Arduino
I just want to make sure I’m even on the right path. Other than the internet are there any recommended books? Any advice would be greatly appreciated.
Thanks in advance,
Frank
