Newbie Alert!! adafruit 16-channel 12-bit pwm problems
Hi all,
Im just trying to get my head around arduino and managed, with help from here, to control my servos so that 1 worked, had a rest, then the next worked etc. All was good until I connected the nano to the adafruit.
I thought i used the same code!!
Anyway, the servos work following the example code. I’ve set the max and min sweep of the servos and then thats the limit of my experience!
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN  200 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  550 // this is the 'maximum' pulse length count (out of 4096)
// our servo # counter
uint8_t servonum = 0;
  Serial.println("16 channel Servo test!");
  pwm.begin();
  pwm.setPWMFreq(60);  // Analog servos run at ~60 Hz updates
  yield();
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= 60;   // 60 Hz
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000;
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
  // Drive each servo one at a time
  Serial.println(servonum);
  for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
    pwm.setPWM(servonum, 0, pulselen);
  for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
  servonum ++;
  if (servonum > 7) servonum = 0;
1 - My servos start at the min value, can they start in the middle and be able to sweep from min to max returning to the middle again?
2 - Is there a dummies guide for newbies like me, I mean, a real dummies guide :smiley:
Any help would be gratefully received.
Thanks,
Jon
slugbut: 1 - My servos start at the min value, can they start in the middle and be able to sweep from min to max returning to the middle again?
Have you tried it - there's nothing to stop you starting from an example and trying things, in fact it can be a good way to learn.
2 - Is there a dummies guide for newbies like me, I mean, a real dummies guide :D
For what exactly? Servos? Adafruit PWM board? Arduino programming in general?
Thanks,
Jon
I'd say look at all the examples you can and try to understand them - reading code is an important skill.
