Newbie at arduino and serial communication
I have recenetly bought an arduino starter kit and I have completed the basic projects. I have the very basic knowledge but I am interested in serial communication mainly in automotive used communication protocols like K-line protocols, CAN, UDS.
How/What could I study in order to be progressively able to understand a communication and practice using arduino? I can't find many stuff explained with these protocols. I can only find information for UART, I2C and SPI. Should I stard with them?
Thanks in advance!
johnman: Hi,
for K-Line would probably need to use a LIN transceiver to read/write. You can find K-line arduino libaries on Github
Same for CAN. loads of arduino compatible libraries and hardware our there... did you even try googling for that!!!
as for CAN UDS its just a diagnostic protocol thats uses CAN as its comm media... again try googling.
you can build the UDS commands once you get the hang of using the CAN libraries
sherzaad: for K-Line would probably need to use a LIN transceiver to read/write. You can find K-line arduino libaries on Github
I don't want to take a ready sketch and a CAN BUS shield and say I did it. I want to understand how they work! Could I read the libraries available in GitHub?
Thanks anyway!
1. Do you know how does UART Port work? If not, please study the following diagrams; write codes to exchange 5 and 7 between UNO and NANO.
2. Then study I2C Bus using UNO and NANO.
3. Then study SPI Port using UNO and NANO.
4. Then study CAN Bus using DUE.
