New to this. Hoping I can use the Arduino to solve a problem. I have an ECU engine computer I would like to interface with a data logging device. They both have serial connections, however the communication protocol is different. What I need to do is poll the ECU device for values 10x per second, then simply reformat it and send it right over to the logging device. Seems pretty simple.
Is this something I can do with the Arduino? I assume I would need a Mega?
That is very much in the realm of the arduino mega. In fact it is almost trivial, you just need to setup 2 serial ports
You could probably use an arduino normal and use the serial port for the faster device, while using a software serial for the slower. Be prepared for a challenge though
One of the devices (the 57600 one) I still need to talk to with a computer. Is it possible to allow communication directly to it through the USB port? Could I put the other 2 devices on say Serial1 and Serial2, let them talk when they need to, and all other times make the USB act like a bridge right to Serial1?
