Newbie coding problem
  if ( a >= b )
    i++;
As the code above, we know that the Arduino microprocessor will keep loop this code forever. So, whenever the if ( a >= b ) condition is met, the i will ++ for sure, and i increasing continuously.
My question is, is there any method to let the machine know: -
if ( a >= b ) is met continuously, "condition on", i++ will only execute once.
then,
if ( a >= b ) is not met, "condition off", ready to meet the condition again.
then,
if ( a >= b ) is met again, "condition on", i++ will only execute once.
also,
if ( a >= b ) is met without changing into ( a < b ), "condition on", do nothing until "condition off" again.
Sure, just put some flags in with a>b to control things.
For example:
if (a>b && runOnce == 0){
runOnce = 1;
i++;
Then something external has to set runOnce back to 0 to let it run again.
State Change Detection, performing an action when a state CHANGES, is a very common problem. The built-in example: File->Examples->02.Digital->StateChangeDetection shows one way to do it.
CrossRoads had solve my coding problem.
johnwasser also help me to link the correlation of my problem with the example.
Thank you very much for the answers! :smiley:
winterpie:
Here is the example I pointed to. The example gets its current state information with:
buttonState = digitalRead(buttonPin);
Since you are interested in the condition "a >= b" rather than the state of an input pin, you would use "a >= b" in place of the "digitalRead()" call. Of course the names "buttonState" and "lastButtonState" don't make sense in your context so you should do a search-and-replace to change them to something like "condition" and "lastCondition". Replace the "buttonPushCounter++;" with what you want to happen when the 'condition' changes from false to true.
  State change detection (edge detection)
  Often, you don't need to know the state of a digital input all the time, but
  you just need to know when the input changes from one state to another.
  For example, you want to know when a button goes from OFF to ON. This is called
  state change detection, or edge detection.
  This example shows how to detect when a button or button changes from off to on
  and on to off.
  The circuit:
  - pushbutton attached to pin 2 from +5V
  - 10 kilohm resistor attached to pin 2 from ground
  - LED attached from pin 13 to ground (or use the built-in LED on most
    Arduino boards)
  created  27 Sep 2005
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState)
    // if the state has changed, increment the counter
    if (buttonState == HIGH)
      // if the current state is HIGH then the button went from off to on:
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  // turns on the LED every four button pushes by checking the modulo of the
  // button push counter. the modulo function gives you the remainder of the
  // division of two numbers:
  if (buttonPushCounter % 4 == 0)
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
