I have a question. For my proyect I want to controller a board which 8 relay's, and I want to used a Arduino as Master mode and the other three as Slave Mode, these are going to controller the relay's board.
My question is as I can to connect the Master and the Slave to send command, ¿using the pin 1 and 2 (serial comunication)? ¿ICSP? I need the all Arduinos are comunication toghter in the same time, because the Master send a command to active a specific relay on the board.
Using the pin 0 and 1 (serial communication) the answer is no. You have to connect an input to an output and while you can connect many inputs to one output you can't connect outputs together.
How far apart are these going to be? maybe you can use radio or RS485 protocols to link them together.
