[Newbie]Converting pulses to volume.
Hi everyone, I really need ur help in one part of the project I'm working on.
I have to convert the number of pulses a agricultural fertilizer machine gives me (I've already done the pulses counter sketch) into a volume of fertilizer (I have the quadratic equation wich is Y = (2E-05)*x^2 + 0.0017x - 0.0338 )
My question is: how could I write the code for having one variable input (the number of pulses ,the X on the equation, will be changing for every position of the machine) and have the result (Y) printed on the serial port.
I founded some codes, like this one,
  float result=0;
   for (float x=0; x <= 256; x++ ){
result = (0.00002 * pow(x,2))  + (0.0017 * x) -0.0338;
Serial.print(x);
Serial.print(" - ");
Serial.print(result);
Serial.println(" ");
for solving equations but the x is not declared as an input...
<<<sorry for my bad english, hope you could help me...Thanks!>>>
pow(x,2)
That's a pretty expensive and inaccurate way to get x * x.
Using float as a loop index is generally NOT a good idea.
But, that makes NO difference.
Thanks PaulS for your help! I'll change those things, but what I need to know is how to declare the x as the number of pulses that the counter i made (This one, using the Encoder.h library and modifying it)
volatile int unsigned pulsos=0;
#include <Encoder.h>
Encoder myEnc(2, 6);
  pinMode (13,INPUT);
  Serial.println("Basic Encoder Test:");
long oldPosition  = myEnc.read();
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    if (digitalRead (13)){    //when pin 13 is HIGH INCREASE
       pulsos--;}
    else{              //when pin 13 is LOW DECREASE
       pulsos++;}
    Serial.println(pulsos);
is sending to me(where the X are the number of pulses) for solving the equation and print the result .
Could you help me?
Why? There is nothing magic about the name x.
   float result = (0.00002 * pulsos * pulsos)  + (0.0017 * pulsos) - 0.0338;
