Newbie date format questions (strftime)
Hi -- I'm trying to print the current time like this:
char tempstring [128];
struct tm timeinfo;
	if (getLocalTime(&timeinfo, 1)) // 1s timeout, but once time acquired from NTP should be immediate
       strftime(tempstring,sizeof(tempstring), "%Y-%m-%d %H:%M:%S", &timeinfo);
       // print tempstring to display, etc.
...it works, but it shows time in 24-hour format, where 3pm is "15". I want 12 hour format, but it zero-pads: %I makes "03". I've read various ways to convince strftime to not zero-pad (%-I, %#I, etc) but none of them seem to work. %r seemed promising but didn't work.
Any way to do this with strftime? Thanks!
https://cplusplus.com/reference/ctime/strftime/
%r is 12 hour clock time
Yes, but it still has that pesky leading zero on the hours.
Thanks! I also tried %r but it didn't print anything... I should say that I'm programming an ESP32 (on the Arduino framework) in vscode/platformIO in case that means anything to this quandary...
You could just remove it
strftime is easy to understand. if the code works but isn't exactly what you want, check the reference and change the format, probably changing %H to %I or %e for space padded hour
You could just roll your own (untested code follows):
       snprintf(tempstring,sizeof(tempstring), "%04u-%02u-%02u %u:%%02u:%02u",
          timeinfo.tm_year+1900,
          timeinfo.tm_mon+1,
          timeinfo.tm_mday,
          timeinfo.tm_hour % 12 ? timeinfo.tm_hour % 12 : 12,
          timeinfo.tm_min,
          timeinfo.tm_sec);
[/quote]
Thanks all, and thanks van_der_decken for that example custom code -- I'll do that. Much obliged.
