Hello,
I am now trying to learn to use Xbee in conjunction with a UNO.
I am having problems using the sample data on an Xbee frame.
when I run the following code:
if (Serial.available()>21)
for (int i=0;i<26;i++)
Serial.print(Serial.read(),HEX);
Serial.print(", ");
Result: Serial monitor reads as follows
7E, 0, 14, 92, 0, 13, A2, 0, 40, AF, 7D, B9, 77, FE, 1, 1, 0, 10, 8, 0, 10, 3, FF, F2, FFFFFFFF, FFFFFFFF,
So now I write a code to retrieve the useful information:
(0,10) Digital samples
(3,FF) Analog sample #1
int dataArray[04] = {};
if (Serial.read()==0x7E)
for (int i=0;i<18;i++)
byte discard=Serial.read();
for (int i=0; i<4; i++)
dataArray = Serial.read();
_ Serial.println(dataArray*);_
_ }_
_ }_
_ }_
_}*_
And result is:
0,16, 3, -1
I understand that 10 becomes Binary 16, and 3 remains the same - but why does FF (Binary 255) become -1??
I am sure there is a sensible reason, and apologise in advance for my possible stupidity ![]()
Best regards,
Mark
