Newbie Help: Adding HM10 to Parola Sketch for "iPhone" to SEND message
Very new to Arduino (my first project). Thanks to previous forum help I was able to do a sketch with Arduino MEGA2560, MAX7219 and Parola so I can type in a message to scroll.
Now I would like to add an HM10 so I could type a message on my iPhone to scroll.
(I should have bought an UNO....but at least it worked with this board)
I also downloaded on my iPhone LightBlue application.
I then did a simple connection HM10 to Arduino (without MAX7219 and without Parola). Then using LightBlue I was able to find and connect (pair) it to the HM10.
So using the LightBlue application seems to work ok. (I think I was connected since the HM10 blinking red light went to solid red light)
My problem is (...after Googling and YouTubing...) I am so confused on how to incorporate HM10 code to my existing Parola sketch to use my iPhone. Below is my working Sketch....Can someone please show what code to add to this sketch so I can SEND scroll message "from my iPhone".
Thank you
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// set to 1 if we are implementing the user interface pot, switch, etc
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#include <MD_UISwitch.h>
#endif
// Turn on debug statements to the serial output
#define DEBUG 0
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 11
#define CLK_PIN   52  // or SCK
#define DATA_PIN  51  // or MOSI
#define CS_PIN    53  // or SS
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Scrolling parameters
#if USE_UI_CONTROL
const uint8_t SPEED_IN = A5;
const uint8_t DIRECTION_SET = 8;  // change the effect
const uint8_t INVERT_SET = 9;     // change the invert
const uint8_t SPEED_DEADBAND = 5;
#endif // USE_UI_CONTROL
uint8_t scrollSpeed = 35;    // default frame delay value
textEffect_t scrollEffect = PA_SCROLL_LEFT;
textPosition_t scrollAlign = PA_LEFT;
uint16_t scrollPause = 2000; // in milliseconds
// Global message buffers shared by Serial and Scrolling functions
#define	BUF_SIZE	75
char curMessage[BUF_SIZE] = { "" };
char newMessage[BUF_SIZE] = {"Hello to my Grandkids "};
bool newMessageAvailable = true;
#if USE_UI_CONTROL
MD_UISwitch_Digital uiDirection(DIRECTION_SET);
MD_UISwitch_Digital uiInvert(INVERT_SET);
void doUI(void)
  // set the speed if it has changed
    int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 10, 150);
    if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
      (speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
      P.setSpeed(speed);
      scrollSpeed = speed;
      PRINT("\nChanged speed to ", P.getSpeed());
  if (uiDirection.read() == MD_UISwitch::KEY_PRESS) // SCROLL DIRECTION
    PRINTS("\nChanging scroll direction");
    scrollEffect = (scrollEffect == PA_SCROLL_LEFT ? PA_SCROLL_RIGHT : PA_SCROLL_LEFT);
    P.setTextEffect(scrollEffect, scrollEffect);
    P.displayClear();
    P.displayReset();
  if (uiInvert.read() == MD_UISwitch::KEY_PRESS)  // INVERT MODE
    PRINTS("\nChanging invert mode");
    P.setInvert(!P.getInvert());
void readSerial(void)
  static char *cp = newMessage;
  while (Serial.available())
    *cp = (char)Serial.read();
    if ((*cp == '\n') || (cp - newMessage >= BUF_SIZE-2)) // end of message character or full buffer
      *cp = '\0'; // end the string
      // restart the index for next filling spree and flag we have a message waiting
      cp = newMessage;
    else  // move char pointer to next position
      cp++;
  Serial.begin(57600);
  Serial.print("\n[Parola Scrolling Display]\nType a message for the scrolling display\nEnd message line with a newline");
#if USE_UI_CONTROL
  uiDirection.begin();
  uiInvert.begin();
  pinMode(SPEED_IN, INPUT);
  doUI();
  P.begin();
  P.displayText(curMessage, scrollAlign, scrollSpeed, scrollPause, scrollEffect, scrollEffect);
#if USE_UI_CONTROL
  doUI();
  if (P.displayAnimate())
    if (newMessageAvailable)
      strcpy(curMessage, newMessage);
      newMessageAvailable = false;
    P.displayReset();
  readSerial();
