Hello, I am very new about microcontroller and arduino, I want to try creating lamp and door controller and automation with java and if possible make an android app of it. Can someone tell me what arduino and other components needed to make it with simplest and minimum budget? and also what software, tools, plugin, etc that needed to create the java based controller program and if possible the android app too?
You are asking a lot of questions in that paragraph.
People here will be able to help you with the Arduino stuff but probably not with the Android stuff.
Your reference to Java is a bit confusing. The Arduino system uses C++ as the programming language.
The Android system is written in Java but you can also use other languages. If you don't know anything about Android programming it might be wisest to study that first. By comparison, the Arduino is simple. You might find this link useful.
...R
Are you looking for something like this?
Krishna
Cool link CodeElectron,
@OP,
Let's break this down:
Well , until you actually state that you have an arduino , you are not IN. (with the IN CLUB;you are window shopping)
IF YOU ARE IN, Rule #1:" Identify uC used (state you uC type)
http://playground.arduino.cc/Interfacing/Java
There projects controlling arduinos with android apps so that's nothing new and certainly doable. (java + arduino =?)
We can't recommend hardware until we have all the specs for the loads to be controlled, (qty, power, etc)
http://atulmaharaj.wordpress.com/2013/05/03/arduino-serial-communication-using-java-and-rxtx/
http://www.lauridmeyer.com/2012/05/arduino-java-usb-serial-communication-all-you-have-to-know/
As already stated, no problem with the android app,
If you want to control Arduino from a Java application I suggest you to take a look to my library.
www.ardulink.org
Luciano
