* midiSwitch - Arduino based midi switcher - looper
* Copyright (C) 2016 Nacho Lucia
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* Pinout:
* d0 -> MIDI in (disconnect when programming arduino via USB)
* d1 -> MIDI out/thru
* d2 -> LCD RS
* d3 -> LCD E (Enable)
* d4 -> LCD D4
* d5 -> LCD D5
* d6 -> LCD D6
* d7 -> LCD D7
* d8 -> BTN 0 Config/back/store
* d9 -> LCD A (backlight led anode)
* d10 -> BTN 1 Down
* d11 -> BTN 2 Up
* d12 -> BTN 3 Ok/select/toggle
* a0-a5 -> OUT relay 0-5 (active high)
* Buttons use internal pull-ups, connect other end to ground.
const char* VERSION = "1.31";
#include <EEPROM.h>
#include <MIDI.h>
#include <SimpleTimer.h>
#include <LiquidCrystal.h>
#include <PButton.h>
#include <Fsm.h>
const byte NUM_PATCHES = 128; //number of patches
const byte NUM_CONTROLS = 6; //number of switches/loops
const byte MIDI_CC_ON_THRESHOLD = 64; //cc values >= this are considered 'on'
const int MESSAGE_DISPLAY_TIME = 1200; //ms flashed mesages are shown
const byte CONFIG_START_ADDRESS = 0; //start address of settings in eeprom
const byte EEPROM_PATCH_START_ADDRESS = 64; //start address of patches in eeprom
const byte LCD_ROWS = 2;
const byte LCD_COLS = 16;
// I/O pins settings
// LCD pins
const byte LCD_RS = 2;
const byte LCD_EN = 3;
const byte LCD_D4 = 4;
const byte LCD_D5 = 5;
const byte LCD_D6 = 6;
const byte LCD_D7 = 7;
const byte LCD_PWM = 9;
// button input pins
const byte BTN_0 = 8;
const byte BTN_1 = 10;
const byte BTN_2 = 11;
const byte BTN_3 = 12;
// relay output pins
const byte RLY_0 = A0;
const byte RLY_1 = A1;
const byte RLY_2 = A2;
const byte RLY_3 = A3;
const byte RLY_4 = A4;
const byte RLY_5 = A5;
* CONSTANT / GLOBAL VARS
// FSM
typedef enum {
EVT_TO_MAIN,
EVT_TO_EDIT_PATCH,
EVT_TO_EDIT_PATCH_PARAMETER,
EVT_TO_SAVE_PATCH,
EVT_TO_SETTINGS,
EVT_TO_EDIT_OPTION,
EVT_TO_RESET
} eventsEnum;
// Custom characters
const byte blqcarac[][8] PROGMEM = {
{0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f},
{0x1f, 0x18, 0x10, 0x10, 0x1f, 0x1f, 0x1f, 0x1c},
{0x1f, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x10},
{0x1f, 0x18, 0x10, 0x10, 0x11, 0x11, 0x11, 0x10},
{0x1f, 0x18, 0x10, 0x10, 0x11, 0x11, 0x11, 0x11},
{0x1f, 0x3, 0x1, 0x1, 0x11, 0x11, 0x11, 0x11},
{0x1f, 0x3, 0x1, 0x1, 0x11, 0x11, 0x11, 0x1},
{0x1f, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x1},
{0x1f, 0x3, 0x1, 0x1, 0x1f, 0x1f, 0x1f, 0x7},
{0x10, 0x11, 0x11, 0x11, 0x10, 0x10, 0x18, 0x1f},
{0x1c, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f},
{0x1c, 0x1f, 0x1f, 0x1f, 0x10, 0x10, 0x18, 0x1f},
{0x11, 0x11, 0x11, 0x11, 0x10, 0x10, 0x18, 0x1f},
{0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x1f},
{0x7, 0x1f, 0x1f, 0x1f, 0x1, 0x1, 0x3, 0x1f},
{0x1, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x1f},
{0x1, 0x11, 0x11, 0x11, 0x1, 0x1, 0x3, 0x1f},
{0x11, 0x11, 0x11, 0x11, 0x1, 0x1, 0x3, 0x1f}
const byte blqnums[10][4] PROGMEM = {
{4,5,12,17},
{0,5,0,13},
{1,6,9,14},
{1,6,11,16},
{2,7,10,15},
{3,8,11,16},//5
{3,8,9,16},
{4,5,0,13},
{3,6,9,16},
{3,6,11,16}
// Settings
const char* CONFIG_VERSION = "v2"; // ID of the settings block, change if struct is modified
struct settingsStruct {
char version[2];
byte midiChannel;
byte ccRelay1, ccRelay2, ccRelay3, ccRelay4;
byte ccLoopA, ccLoopB;
bool toggleMode;
byte brightness;
} _settings;
typedef enum {
ST_CHANNEL,
ST_TOGGLE,
ST_CC_R1,
ST_CC_R2,
ST_CC_R3,
ST_CC_R4,
ST_CC_LA,
ST_CC_LB,
ST_BRIGHTNESS,
ST_INFO,
OPTIONSENUM_LENGTH
} optionsEnum;
const char optionName00[] PROGMEM = "Canal MIDI";
const char optionName01[] PROGMEM = "Modo CC";
const char optionName02[] PROGMEM = "CC Switch 1";
const char optionName03[] PROGMEM = "CC Switch 2";
const char optionName04[] PROGMEM = "CC Switch 3";
const char optionName05[] PROGMEM = "CC Switch 4";
const char optionName06[] PROGMEM = "CC Loop A";
const char optionName07[] PROGMEM = "CC Loop B";
const char optionName08[] PROGMEM = "Brillo";
const char optionName09[] PROGMEM = "Informacion";
const char* const _settingsItemName[] PROGMEM = {
optionName00, optionName01, optionName02, optionName03, optionName04,
optionName05, optionName06, optionName07, optionName08, optionName09
typedef void (*callback) (void);
//Global vars
byte _patch = 0;
byte _relayStatus = 0xFF; //all off
byte _editPatchPosition = 0;
bool _isPatchModified = false;
bool _isConfigModified = false;
byte _tempPatchNumber = 0;
optionsEnum _settingsItem;
byte _settingsValue;
byte _tempSettingsValue;
* Global instances
SimpleTimer _timer;
PButton btn_back = PButton(BTN_0);
PButton btn_down = PButton(BTN_1);
PButton btn_up = PButton(BTN_2);
PButton btn_ok = PButton(BTN_3);
LiquidCrystal lcd(LCD_RS, LCD_EN, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
MIDI_CREATE_DEFAULT_INSTANCE();
//fsm
State stateSplash(NULL, NULL);
State stateMain(&onMainEnter, NULL);
State stateEditPatch(&onEditPatchEnter, &onEditPatchExit);
State stateSavePatch(&onSavePatchEnter, &onSavePatchExit);
State stateSettings(&onSettingsEnter, NULL);
State stateEditOption(&onEditOptionEnter, &onEditOptionExit);
State stateReset(&onResetEnter, NULL);
Fsm fsm(&stateSplash);
//buttons
void resetButtons() {
btn_ok.resetEvents();
btn_back.resetEvents();
btn_up.resetEvents();
btn_down.resetEvents();
* CHANGE STATE
void goToMain() { fsm.trigger(EVT_TO_MAIN); }
void goToEditPatch() { fsm.trigger(EVT_TO_EDIT_PATCH); }
void goToSavePatch() { fsm.trigger(EVT_TO_SAVE_PATCH); }
void goToSettings() { fsm.trigger(EVT_TO_SETTINGS); }
void goToEditOption() { fsm.trigger(EVT_TO_EDIT_OPTION); }
void goToReset() { fsm.trigger(EVT_TO_RESET); }
* STATES
* MAIN
void onMainEnter() {
MIDI.setHandleControlChange(midiControlChangeHandler);
MIDI.setHandleProgramChange(midiProgramChangeHandler);
updateMainDisplay();
_tempPatchNumber = _patch;
btn_up.addPushEvent(increasePatch); //immediate change
btn_up.addRepeatEvent(increaseTempPatchNumber, updatePatchNumber);
btn_down.addPushEvent(decreasePatch);
btn_down.addRepeatEvent(decreaseTempPatchNumber, updatePatchNumber);
btn_back.addShortEvent(goToEditPatch);
btn_back.addLongEvent(goToSettings);
void increasePatch(){
changePatch(incDecValue(_patch, NUM_PATCHES, +1));
void decreasePatch(){
changePatch(incDecValue(_patch, NUM_PATCHES, -1));
void updatePatchNumber() {
changePatch(_tempPatchNumber);
* EDIT PATCH
void onEditPatchEnter() {
updateEditPatchDisplay();
btn_up.addPushEvent(editNextRelay);
btn_down.addPushEvent(editPrevRelay);
btn_back.addShortEvent(goToMain);
btn_back.addLongEvent(goToSavePatch);
btn_ok.addPushEvent(editToggleRelay);
void editNextRelay(){
changeEditPatchPosition(incDecValue(_editPatchPosition, NUM_CONTROLS, +1));
void editPrevRelay(){
changeEditPatchPosition(incDecValue(_editPatchPosition, NUM_CONTROLS, -1));
void editToggleRelay() {
toggleRelayStatus(_editPatchPosition);
void onEditPatchExit() {
lcdClearEditPatchPosition();
* SAVE PATCH
void onSavePatchEnter() {
MIDI.setHandleProgramChange(midiLearnPC);
btn_up.addRepeatEvent(increaseTempPatchNumber);
btn_down.addRepeatEvent(decreaseTempPatchNumber);
btn_ok.addShortEvent(saveModifiedPatch);
blinkBigNumbers(true);
lcd.setCursor(4,1);
lcd.write(0x7F);
lcd.print(F(" Guardar en"));
void onSavePatchExit() {
blinkBigNumbers(false);
void increaseTempPatchNumber(){
_tempPatchNumber = incDecValue(_tempPatchNumber, NUM_PATCHES, +1);
lcdPrintBigNumber(_tempPatchNumber);
void decreaseTempPatchNumber(){
_tempPatchNumber = incDecValue(_tempPatchNumber, NUM_PATCHES, -1);
void saveModifiedPatch() {
savePatch(_tempPatchNumber, _relayStatus);
if (_tempPatchNumber != _patch) {
goToMain();
flashMessage(F(" Guardado "), lcdInitStatus);
void midiLearnPC(byte channel, byte number) {
_tempPatchNumber = number;
* SETTINGS
void onSettingsEnter() {
btn_up.addRepeatEvent(nextOption);
btn_down.addRepeatEvent(prevOption);
btn_ok.addShortEvent(okEditOption);
btn_back.addLongEvent(saveSettingsAndExit);
_settingsValue = *optionValuePt(_settingsItem);
lcdPrintSettingsDisplay(_settingsValue, _settingsItem);
void nextOption(){
changeSettingsItem((optionsEnum) incDecValue(_settingsItem, OPTIONSENUM_LENGTH, +1));
void prevOption(){
changeSettingsItem((optionsEnum) incDecValue(_settingsItem, OPTIONSENUM_LENGTH, -1));
void okEditOption(){
if(_settingsItem == ST_INFO) {
splash();
resetButtons();
btn_back.addShortEvent(onSettingsEnter);
btn_ok.addShortEvent(onSettingsEnter);
else {
goToEditOption();
void saveSettingsAndExit() {
if (_isConfigModified) {
saveSettings();
goToMain();
* EDIT OPTION
void onEditOptionEnter() {
btn_up.addRepeatEvent(increaseOptionValue, applySettings);
btn_down.addRepeatEvent(decreaseOptionValue, applySettings);
btn_ok.addShortEvent(okOptionEdit);
btn_back.addShortEvent(cancelOptionEdit);
_tempSettingsValue = _settingsValue;
lcdPrintEditOptionDisplay(_settingsValue, _settingsItem);
if (_settingsItem >= ST_CC_R1 && _settingsItem <= ST_CC_LB) {
MIDI.setHandleControlChange(midiLearnCC); //midi learn CC
MIDI.setHandleControlChange(NULL);
void increaseOptionValue() {
changeOptionValue(incOptionValue(_settingsValue, _settingsItem), _settingsItem);
updateEditOptionDisplay();
void decreaseOptionValue() {
changeOptionValue(decOptionValue(_settingsValue, _settingsItem), _settingsItem);
void cancelOptionEdit() {
changeOptionValue(_tempSettingsValue, _settingsItem);
applySettings();
goToSettings();
void okOptionEdit() {
_isConfigModified = _isConfigModified || (_settingsValue != _tempSettingsValue);
goToSettings();
void onEditOptionExit() {
lcdClearEditOptionDisplay();
void midiLearnCC(byte channel, byte number, byte value) {
changeOptionValue(number, _settingsItem);
* RESET
void onResetEnter(){
_tempSettingsValue = false;
lcdPrintResetDisplay(false, F(" Borrar todo!!?"));
btn_up.addShortEvent(nextResetValue);
btn_down.addShortEvent(nextResetValue);
btn_ok.addShortEvent(confirmReset);
void nextResetValue(){
_tempSettingsValue = !_tempSettingsValue;
lcdPrintResetDisplay(_tempSettingsValue,"");
void confirmReset() {
if (_tempSettingsValue) { // yes
askAgainReset();
goToMain();
void askAgainReset() {
btn_ok.addShortEvent(lastConfirmReset);
lcdPrintResetDisplay(_tempSettingsValue, F(" Seguro? "));
void lastConfirmReset() {
factoryReset();
applySettings();
goToMain();
flashMessage(F(" Borrado! "), lcdInitStatus);
goToMain();
void flashMessage(const String& message, callback cb){
lcd.setCursor(4,1);
lcd.print(message);
_timer.setTimeout(MESSAGE_DISPLAY_TIME, cb);
* TRANSITIONS
void stateTransition(){
resetButtons();
void initMainTransition(){
initMainDisplay();
resetButtons();
* MAIN
void lcdInitBigNumbers() {
lcd.setCursor(0,0);
lcd.write((byte) 0);
lcd.write(1);
lcd.write(4);
lcd.write(5);
lcd.setCursor(0,1);
lcd.write(2);
lcd.write(3);
lcd.write(6);
lcd.write(7);
void lcdInitStatus() {
lcd.setCursor(4,1);
lcd.print(F(" 1 2 3 4 A B"));
void initLcd() {
lcd.begin(LCD_COLS, LCD_ROWS);
analogWrite(LCD_PWM, brightnessLevelToValue(_settings.brightness));
void initMainDisplay() {
lcdInitBigNumbers();
lcdInitStatus();
* SETTINGS -- LCD
void lcdPrintSettingsDisplay(byte value, optionsEnum option){
const byte ellipsisChar[8] = {0, 0, 0, 0, 0, 0, 0x15, 0};
lcd.createChar(2, (byte*)ellipsisChar);
//top row
lcd.setCursor(0,0);
lcd.print(F("Opciones "));
lcd.setCursor(LCD_COLS - 1 - (OPTIONSENUM_LENGTH < 10 ? 1 : 2)
- (option +1 <10 ? 1 : 2),0);
lcd.print(option + 1);
lcd.print('/');
lcd.print(OPTIONSENUM_LENGTH);
//bottom row
lcd.setCursor(0,1);
lcd.print(optionText(option));
if (settingsValueText(value, option).length() > 0) lcd.print(':');
else lcd.write(2);
lcd.print(F(" "));
lcdPrintOptionValue(value, option);
//config modified flag
lcd.setCursor(8,0); //8 = opciones text length
lcd.write(_isConfigModified ? 0xEB : ' ');
void lcdPrintEditOptionDisplay(byte value, optionsEnum option) {
lcdPrintSettingsDisplay(value, option);
const byte arrowsChar[8] = {0x1F, 0x1B, 0x11, 0x1F, 0x1F, 0x11, 0x1B, 0x1F};
lcd.createChar(1, (byte*)arrowsChar);
lcdPrintEditOptionMarker(value, option);
lcd.blink();
void lcdPrintOptionValue(byte value, optionsEnum option) {
String valueText = settingsValueText(value, option);
lcd.setCursor(optionText(option).length() + 1,1); //right to option name
lcd.print(F(" "));
lcd.setCursor(LCD_COLS - valueText.length(),1);
lcd.print(valueText);
void lcdPrintEditOptionMarker(byte value, optionsEnum option) {
byte pos = LCD_COLS - 1 - settingsValueText(value, option).length();
lcd.setCursor(pos,1);
lcd.write(1);
void updateEditOptionDisplay(){
lcdPrintOptionValue(_settingsValue, _settingsItem);
lcdPrintEditOptionMarker(_settingsValue, _settingsItem);
void lcdClearEditOptionDisplay() {
lcd.noBlink();
void changeSettingsItem(optionsEnum item){
_settingsItem = item;
lcdPrintSettingsDisplay(*optionValuePt(item), item);
byte* optionValuePt(optionsEnum option) {
switch (_settingsItem) {
case ST_CHANNEL: return &_settings.midiChannel;
case ST_TOGGLE: return (byte*) &_settings.toggleMode;
case ST_CC_R1: return &_settings.ccRelay1;
case ST_CC_R2: return &_settings.ccRelay2;
case ST_CC_R3: return &_settings.ccRelay3;
case ST_CC_R4: return &_settings.ccRelay4;
case ST_CC_LA: return &_settings.ccLoopA;
case ST_CC_LB: return &_settings.ccLoopB;
case ST_BRIGHTNESS: return &_settings.brightness;
String optionText(optionsEnum option){
char buffer[16];
strcpy_P(buffer, (char*)pgm_read_word(&(_settingsItemName[option])));
return buffer;
String settingsValueText(byte value, optionsEnum option){
char buffer[8];
// byte value = *optionValuePt(option);
case ST_CHANNEL:
if (value == 0) return F("Omni");
case ST_TOGGLE:
if (value) return F("Toggle");
else return F("Normal");
/* case ST_BRIGHTNESS:
if (value <= 0) return F("Off");
if (value >= 5) return F("Max");
break; */
case ST_INFO:
return "";
sprintf(buffer, "%d",value);
return buffer;
void applySettings() {
MIDI.setInputChannel(_settings.midiChannel);
byte incDecValue(byte value, byte max, int offset) {
return (offset >= 0) ? ((value + offset) % (max))
: (((value + offset) < 0) ? max + offset
: value + offset); }
byte incDecOptionValue(byte value, optionsEnum option, int offset){
switch (option) {
case ST_CHANNEL: return incDecValue(value, 17, offset);
case ST_TOGGLE: return !value;
case ST_CC_R1:
case ST_CC_R2:
case ST_CC_R3:
case ST_CC_R4:
case ST_CC_LA:
case ST_CC_LB: return incDecValue(value, 128, offset);
case ST_BRIGHTNESS: return incDecValue(value, 6, offset);
byte incOptionValue(byte value, optionsEnum option) {
return incDecOptionValue(value, option, +1);
byte decOptionValue(byte value, optionsEnum option) {
return incDecOptionValue(value, option, -1);
void updateOptionValue(byte value, optionsEnum option){
*optionValuePt(option) = value;
void changeOptionValue(byte value, optionsEnum option) {
_settingsValue = value;
updateOptionValue(value, option);
byte brightnessLevelToValue(byte level){
if (level == 5) return 255;
else if (level == 0) return 0;
return 1 << level + 3;
* MAIN -- LCD
void lcdPrintBigNumber(byte number){
byte tens=((number+1)/10)%10;
byte units=(number+1)%10;
byte bufferTens[8];
byte bufferUnits[8];
for (byte i=0; i<4; i++) {
for (byte j=0; j<8; j++) {
bufferTens[j] = pgm_read_byte( &blqcarac[pgm_read_byte( &blqnums[tens][i] )][j] );
bufferUnits[j]= pgm_read_byte( &blqcarac[pgm_read_byte( &blqnums[units][i] )][j] );
if (number >= 99) { // invert character
bufferTens[j] = ~bufferTens[j];
bufferUnits[j] = ~bufferUnits[j];
lcd.createChar(i,bufferTens);
lcd.createChar(i+4,bufferUnits);
void lcdClearBigNumbers() {
lcd.setCursor(0,0);
lcd.print(F(" "));
lcd.setCursor(0,1);
lcd.print(F(" "));
void lcdPrintRelayStatus(byte status) {
for (byte i=0; i<NUM_CONTROLS; i++) {
lcd.setCursor(5+2*i,0);
lcd.write(status >> i & 1 ? 0x10 : 0xFF);
lcd.print(' ');
void updateMainDisplay(){
lcdPrintBigNumber(_patch);
lcdPrintRelayStatus(_relayStatus);
lcdPrintPatchModifiedFlag(_isPatchModified);
void blinkBigNumbers(bool active) {
static byte timerId;
if (active) {
timerId = _timer.setInterval(600, toggleBlinkBigNumbers);
_timer.deleteTimer(timerId);
void toggleBlinkBigNumbers(){
lcdClearBigNumbers();
_timer.setTimeout(200, lcdInitBigNumbers);
void changeEditPatchPosition(byte position) {
if (position < 0) position = NUM_CONTROLS - 1;
else if (position >= NUM_CONTROLS) position = 0;
_editPatchPosition = position;
void updateEditPatchDisplay() {
lcd.setCursor(4+2*_editPatchPosition,1);
lcd.write(0x7e);
void lcdClearEditPatchPosition() {
lcdInitStatus();
void lcdPrintResetDisplay(bool reset, const String& message){
if (message.length() > 0) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(message);
lcd.setCursor(1,1);
lcd.print(F(" No Si"));
lcd.setCursor(reset ? 11 : 1, 1);
lcd.write(0x7E);
* CONTROL -- PATCH
byte changePatch(byte number){
if (number >= 0 && number < NUM_PATCHES) {
_patch = number;
changeRelayStatus(loadPatch(number));
// _tempPatchNumber = _patch;
byte loadPatch(byte number) {
byte status = EEPROM.read(EEPROM_PATCH_START_ADDRESS + number);
return status; //EEPROM has value 0xFF if never written to
void savePatch(byte number, byte status) {
EEPROM.update(EEPROM_PATCH_START_ADDRESS + number, status);
void factoryReset() {
resetPatchMemory();
resetSettingsMemory();
void resetPatchMemory(){
for (int i = 0; i < NUM_PATCHES; i++) {
EEPROM.update(EEPROM_PATCH_START_ADDRESS + i, 0xFF);
_patch = 0;
changeRelayStatus(0xFF);
void resetSettingsMemory(){
for (int i = 0; i < sizeof(settingsStruct); i++) {
EEPROM.update(CONFIG_START_ADDRESS + i, 0xFF);
loadDefaultSettings();
void lcdPrintPatchModifiedFlag(bool modified) {
lcd.setCursor(4,0);
lcd.write(_isPatchModified ? 0xEB : ' ');
void loadDefaultSettings(){
strcpy(_settings.version,CONFIG_VERSION);
_settings.midiChannel = MIDI_CHANNEL_OMNI;
_settings.ccRelay1 = 75;
_settings.ccRelay2 = 76;
_settings.ccRelay3 = 77;
_settings.ccRelay4 = 78;
_settings.ccLoopA = 82;
_settings.ccLoopB = 83;
_settings.toggleMode = false;
_settings.brightness = 5;
* CONTROL -- STATUS
void changeRelayStatus(byte status) {
// inverted status, relays are active low
digitalWrite(RLY_0, status & 1 << 0); //status bit 0
digitalWrite(RLY_1, status & 1 << 1); //status bit 1
digitalWrite(RLY_2, status & 1 << 2);
digitalWrite(RLY_3, status & 1 << 3);
digitalWrite(RLY_4, status & 1 << 4);
digitalWrite(RLY_5, status & 1 << 5);
_relayStatus = status;
void setRelayStatus(byte pos, bool active) {
if (active) changeRelayStatus(_relayStatus & ~(1 << pos));
else changeRelayStatus(_relayStatus | (1 << pos));
_isPatchModified = true;
void toggleRelayStatus(byte pos) {
changeRelayStatus(_relayStatus ^ (1 << pos));
* MIDI
void midiControlChangeHandler(byte channel, byte number, byte value) {
if (_settings.toggleMode && value >= MIDI_CC_ON_THRESHOLD) {
if (number == _settings.ccRelay1) toggleRelayStatus(0);
if (number == _settings.ccRelay2) toggleRelayStatus(1);
if (number == _settings.ccRelay3) toggleRelayStatus(2);
if (number == _settings.ccRelay4) toggleRelayStatus(3);
if (number == _settings.ccLoopA) toggleRelayStatus(4);
if (number == _settings.ccLoopB) toggleRelayStatus(5);
else if (!_settings.toggleMode) {
if (number == _settings.ccRelay1) setRelayStatus(0, value >= MIDI_CC_ON_THRESHOLD);
if (number == _settings.ccRelay2) setRelayStatus(1, value >= MIDI_CC_ON_THRESHOLD);
if (number == _settings.ccRelay3) setRelayStatus(2, value >= MIDI_CC_ON_THRESHOLD);
if (number == _settings.ccRelay4) setRelayStatus(3, value >= MIDI_CC_ON_THRESHOLD);
if (number == _settings.ccLoopA) setRelayStatus(4, value >= MIDI_CC_ON_THRESHOLD);
if (number == _settings.ccLoopB) setRelayStatus(5, value >= MIDI_CC_ON_THRESHOLD);
void midiProgramChangeHandler(byte channel, byte number) {
changePatch(number);
* CONFIG
void loadSettings() {
EEPROM.get(CONFIG_START_ADDRESS, _settings);
if (strcmp(_settings.version,CONFIG_VERSION) != 0) {
void saveSettings() {
EEPROM.put(CONFIG_START_ADDRESS, _settings);
* SPLASH
void splash() {
lcd.setCursor(0,0);
lcd.print(F("midiSwitch v"));
lcd.print(VERSION);
lcd.setCursor(0,1);
lcd.print(F("N. Lucia - 2016"));
* SETUP
pinMode(LCD_PWM,OUTPUT);
pinMode(BTN_0, INPUT_PULLUP);
pinMode(BTN_1, INPUT_PULLUP);
pinMode(BTN_2, INPUT_PULLUP);
pinMode(BTN_3, INPUT_PULLUP);
pinMode(RLY_0, OUTPUT);
pinMode(RLY_1, OUTPUT);
pinMode(RLY_2, OUTPUT);
pinMode(RLY_3, OUTPUT);
pinMode(RLY_4, OUTPUT);
pinMode(RLY_5, OUTPUT);
//Serial.begin(9600);
//Serial.println("INICIO");
loadSettings();
changePatch(_patch);
initLcd();
splash();
_timer.setTimeout(MESSAGE_DISPLAY_TIME, goToMain); //exit splash screen
MIDI.begin(_settings.midiChannel);
//Serial.begin(115200); //for hairless midi testing
fsm.add_transition(&stateSplash, &stateMain, EVT_TO_MAIN, &initMainTransition);
fsm.add_transition(&stateEditPatch, &stateMain, EVT_TO_MAIN, &stateTransition);
fsm.add_transition(&stateSavePatch, &stateMain, EVT_TO_MAIN, &stateTransition);
fsm.add_transition(&stateSettings, &stateMain, EVT_TO_MAIN, &initMainTransition);
fsm.add_transition(&stateReset, &stateMain, EVT_TO_MAIN, &initMainTransition);
fsm.add_transition(&stateEditPatch, &stateSavePatch, EVT_TO_SAVE_PATCH, &stateTransition);
fsm.add_transition(&stateMain, &stateEditPatch, EVT_TO_EDIT_PATCH, &stateTransition);
fsm.add_transition(&stateSavePatch, &stateEditPatch, EVT_TO_EDIT_PATCH, &stateTransition);
fsm.add_transition(&stateMain, &stateSettings, EVT_TO_SETTINGS, &stateTransition);
fsm.add_transition(&stateEditOption, &stateSettings, EVT_TO_SETTINGS, &stateTransition);
fsm.add_transition(&stateSettings, &stateEditOption, EVT_TO_EDIT_OPTION, &stateTransition);
fsm.add_transition(&stateSplash, &stateReset, EVT_TO_RESET, NULL);
if (digitalRead(BTN_0) == LOW) { //back pressed on startup
_timer.deleteTimer(0);
goToReset();
_timer.run();
MIDI.read();
btn_up.update();
btn_down.update();
btn_back.update();
btn_ok.update();
i've loaded all the library... thanks guys for the help...
Where did you get this code?
Do you have a link to the source?
please insert a full error output to the message as text using code tags
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:209:29: error: no matching function for call to 'State::State(NULL, NULL)'
In file included from C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:48:0:
C:\Users\ARJAY\Documents\Arduino\libraries\arduino-fsm/Fsm.h:29:3: note: candidate: State::State(void (*)(), void (*)(), void (*)())
State(void (*on_enter)(), void (*on_state)(), void (*on_exit)());
C:\Users\ARJAY\Documents\Arduino\libraries\arduino-fsm/Fsm.h:29:3: note: candidate expects 3 arguments, 2 provided
C:\Users\ARJAY\Documents\Arduino\libraries\arduino-fsm/Fsm.h:27:8: note: candidate: constexpr State::State(const State&)
struct State
C:\Users\ARJAY\Documents\Arduino\libraries\arduino-fsm/Fsm.h:27:8: note: candidate expects 1 argument, 2 provided
C:\Users\ARJAY\Documents\Arduino\libraries\arduino-fsm/Fsm.h:27:8: note: candidate: constexpr State::State(State&&)
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:210:35: error: no matching function for call to 'State::State(void (*)(), NULL)'
struct State
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:211:57: error: no matching function for call to 'State::State(void (*)(), void (*)())'
struct State
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:212:57: error: no matching function for call to 'State::State(void (*)(), void (*)())'
struct State
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:213:43: error: no matching function for call to 'State::State(void (*)(), NULL)'
struct State
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:214:60: error: no matching function for call to 'State::State(void (*)(), void (*)())'
struct State
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:215:37: error: no matching function for call to 'State::State(void (*)(), NULL)'
struct State
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino: In function 'void flashMessage(const String&, callback)':
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:499:12: error: 'class SimpleTimer' has no member named 'setTimeout'
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino: In function 'void blinkBigNumbers(bool)':
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:745:61: error: no matching function for call to 'SimpleTimer::setInterval(int, void (&)())'
In file included from C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:45:0:
C:\Users\ARJAY\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:23:10: note: candidate: void SimpleTimer::setInterval(uint64_t)
void setInterval(uint64_t interval);
C:\Users\ARJAY\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:23:10: note: candidate expects 1 argument, 2 provided
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:747:13: error: 'class SimpleTimer' has no member named 'deleteTimer'; did you mean 'SimpleTimer'?
SimpleTimer
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino: In function 'void toggleBlinkBigNumbers()':
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:754:11: error: 'class SimpleTimer' has no member named 'setTimeout'
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino: In function 'void setup()':
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:960:10: error: 'class SimpleTimer' has no member named 'setTimeout'
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:985:12: error: 'class SimpleTimer' has no member named 'deleteTimer'; did you mean 'SimpleTimer'?
SimpleTimer
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino: In function 'void loop()':
C:\Users\ARJAY\Desktop\midiSwitch-master\midiSwitch\midiSwitch.ino:991:10: error: 'class SimpleTimer' has no member named 'run'
_timer.run();
exit status 1
Compilation error: no matching function for call to 'State::State(NULL, NULL)'
This project has very little to do with your code.
Judging by the error messages, the libraries you installed are not the same that the author of the code used.
For example, you need to take the SipleTimer library here:
i thinks i've downloaded to many library for the FSM. so i delete some of them. and this happened
My congratulations!
If the problem was solved, please mark a most valuable answer as "solution" to help another users with similar problem.
thanks again for answering on my post.
