NEWBIE - How to read what is on Arduino Pro Mini
Thank you for the prompt reply!
If I could just download what is installed on the Pro Mini on the unit that isn't working, and do the same for the unit that is working, then I could compare the two downloaded files to see if they are the same using a file comparison utility program. If they are, then the problem is likely not the code itself but something else on the unit. If they are different, then the problem could be the Pro Mini on the unit that doesn't work. I just need a download utility for the Pro Mini.
Joe
