Newbie in need of help for IR Controlled Robot
Hello, I'm trying to make a robot controlled by an IR remote. I've been trying to make it work for days but 3rd and 4th motor dont seem to work and I also can't change the directions of the ones that work.
Here's the code:
#include<IRremote.h>
const int RemotePin=8;
IRrecv irrecv(RemotePin);
decode_results results;
int in1=3;
int in2=5;
int in3=6;
int in4=9;
int enA=10;
int enB=11;
  irrecv.enableIRIn();
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
    if(irrecv.decode(&results))
       if (results.value==0xFF18E7)//Press UP Button
         Forward();
       else if (results.value==0xFF4AB5)//Press Down Button
         Backward();
       else if (results.value==0xFF10EF)//Press Left Button
         Left();
       else if (results.value==0xFF5AA5)//Press Right Button
         Right();
       else if (results.value==0xFF38C7)//Stop
         Stop();
      irrecv.resume();
 void Forward()
    digitalWrite(in1,HIGH);
    digitalWrite(in2,LOW);
    digitalWrite(in3,HIGH);
    digitalWrite(in4,LOW);
    analogWrite(enA, 150);
    analogWrite(enB, 150);
 void Backward()
    digitalWrite(in1,LOW);
    digitalWrite(in2,HIGH);
    digitalWrite(in3,LOW);
    digitalWrite(in4,HIGH);
 void Right()
 void Left()
 void Stop()
    analogWrite(enA, 0);
    analogWrite(enB, 0);
Pin 11 (neither 3) can't be used for analogWrite while using IRremote library.
Also I suggest to update to newest version and #include <IRremote.hpp>.
Thank you, it works now!
You're welcome.
