Newbie in need of help
Hi there, community. I´m new to the arduino and plan to learn a lot. I´m not sure, wheter this is the right place to post my question (i couldn´t find games&play), and I do know that a lot of people might say: ask google, start learning from the scratch... I´m willing to do this, but my first "big" project is kind of a quick need. Next sunday we have a big festival and we are building a lot of games for children to play. I found one interesting game that I want to build in a "wooden edition" but with the extension of an arduino and I do need help in programming and connecting (I do know basics). Here is how the game works. In front of the kid is a hand with 5 fingers (yep, that´s right) in each finger are two rgb-leds or a couple of colored leds. When the game starts, there are two leds on each finger on and the kid has to grab hair-bands and has to put them the right way on it´s own hand. The colors are supposed to be random. For example, the thumbs has 2xleds on, one green, one blue. The kid has to put a green and a blue hair-band on it´s finger. Once all the hair bands are in the correct place, the kid touches the hand and a timer stops, giving out the time needed to fullfil the task. (for I don´t have a display, I´m looking for an alternativ). We have a arduino (uno & mega), a couple of leds. If anyone can help, I would really appreciate. Thanks, Uli
Sounds like variation on Simon game, google that.
No I do not see any memory component (isnt that what Simon Says is?)
here is what I have translated the description to Arduino task On button push a random set of lights turn on. Timer starts. On other button push timer stops (display...?)
It doesnt matter if the light is an RGB or seperate LEDs. You have 10 LEDs or so - simple direct driving - through a resistor - for each pin will do. The program will only be a handfuld of lines for the lights.
The timer is dead easy: note millis() at start button, subtract from millis() when stop. divide by 1000 and display. The display is your biggest challenge here - if nothing else use a laptop and a terminal emulator showing the serial out with a BIG font.
Msquare is right, this is exactly what we are trying to build.
int finger11 = 13; /* whereas n1 is the upper led / int finger12 = 12; / n2 is the lower led */ int finger21 = 11; int finger22 = 10; int finger31 = 9; int finger32 = 8; int finger41 = 7; int finger42 = 6; int finger51 = 5; int finger52 = 4; int timer = 3; void setup() { pinMode(led, OUTPUT); } void loop() { random.color for finger 11 to 52 start.timer stop.timer when key pressed and display time start over when key is pressed again }
In the attachment is an image, on how it is supposed to look like in the end
(sorry forgot one led on the second finger top from the right)
lightview: Msquare is right, this is exactly what we are trying to build.
Happy to help - but what is the question? A programming issue? A wiring issue?
BTW - use the Preview button and the "#" button so you can work out how to show program code in your posts
OK here are some answers. Just like in Jeopardy - what is the question :) :grin: pinMode(led, OUTPUT);should be
pinMode(finger11, OUTPUT);
pinMode(finger12, OUTPUT);
  // :  and so on
But really you should use an array.
Buttons should be wired between the Arduino pin and Ground. The input pin (and it can be any except 13) is then initialised with
pinMode(startbutton, INPUT_PULLUP);
Thanks a lot, indeed it´s a programming question, the wiring shouldn´t be a problem
Can someone help me out and tell me what is wrong with this code? It's giving me a function-definition is not allowed here before { token
// define pins to be used
int S1 = 2; //switch 1 int S2 = 3; int S3 = 4; int L1 = 5; // light 1 int L2 = 6; int L3 = 7; int B = 8; //buzzer
void setup() { // initialize the digital pins. // assume switches will wire from ground to input pins pinMode(S1, INPUT_PULLUP); pinMode(S2, INPUT_PULLUP); pinMode(S3, INPUT_PULLUP); pinMode(L1, OUTPUT); // leds wired from output pin to ground } pinMode(L2, OUTPUT); pinMode(L3, OUTPUT); pinMode(B, OUTPUT); // buzzer wired from output pin to ground }
void loop() { if (!digitalRead(S1)) { digitalWrite(L1,HIGH); // turn on lamp 1 digitalWrite(B,HIGH); // turn on buzzer delay(500); // wait 2 seconds digitalWrite(B,LOW); // turn off buffer delay(5000); // wait 28 more seconds digitalWrite(L1,LOW); // turn off lamp 1 } if (!digitalRead(S2)) { digitalWrite(L2,HIGH); // turn on lamp 2 digitalWrite(B,HIGH); // turn on buzzer delay(500); // wait 2 seconds digitalWrite(B,LOW); // turn off buffer delay(5000); // wait 28 more seconds digitalWrite(L2,LOW); // turn off lamp 2 } if (!digitalRead(S3)) { digitalWrite(L3,HIGH); // turn on lamp 3 digitalWrite(B,HIGH); // turn on buzzer delay(500); // wait 2 seconds digitalWrite(B,LOW); // turn off buffer delay(5000); // wait 28 more seconds digitalWrite(L3,LOW); // turn off lamp 3 } }
I fixed it. You were missing a bunch of "}" The first error message you had was due to the loop() started before a "}" closed the previous void setup() .
Notice that the code here is in a nice seperate box, which makes reading it easier. Also note the indentation - the editor does it if you press ^T. Read the top post on how to post to get these details right.
I do not know if this is the logic you want. The code you supplied had some "}" inside comments (after a "//" on the same line) and thus do not count. I have just sprinkled "}" at the end until it compiled.
int S2 = 3;
int S3 = 4;
int L2 = 6;
int L3 = 7;
int B = 8; //buzzer
Also note that code like delay(500) ; // wait 2 secondsis very confusing. The code says half a second, the comment says 2 seconds. Which did you want?
