Newbie, is there a better, more simple way to code this?
Hello all! I am a near complete noob working my way through a tutorial book for Arduino. I jut wrote this code for simply flashing “S.O.S.” using the onboard LED of the Uno. The code works fine, however as I have a tendency to over-complicate everything, I am curious what a simpler / more sleek way may have been to write the code? Thank you all in advance for any insight!
pinMode(LED_BUILTIN, OUTPUT);
int i = 0;
bool doneFlag = false;
if (i <= 2){
digitalWrite(LED_BUILTIN, HIGH);
delay (250);
digitalWrite(LED_BUILTIN, LOW);
delay (250);
i = ++i;
else if (i >=3 && i <= 5){
  if (doneFlag == false){
    doneFlag = !doneFlag;
delay (500);
delay (500);
i = ++i;
else if (i >=6 && i <= 8){
 if (doneFlag){
delay (250);
delay (250);
i = ++i;
else if (i = 9){
delay (3000);
i = 0;
[code]
Look at examples of a "for" loop.
Paul
if (i = 9)
Oops
i = ++i;
"i++;" is much shorter.
Give this a shot
Perhaps using arrays will help you in more ways than you ask…
I didn’t compile or run this code - but is guaranteed 99% valid - maybe some debugging for you!
Certainly room for improvement !
// just so we can use words down below...
#define dit 0
#define dah 1
#define gap 2
#define ON HIGH
#define OFF LOW
// Your char array can be any message - or multiple preefined messages in a 2D array
uint8_t morse_string[] = {dit, dit, dit, gap, dah, dah, dah, gap, dit, dit, dit }; // SOS
// better still you could create a ascii->morse conversion function
// we'll use delay here - to simplify the explanation,
// but should rewrite using millis() timing
int dit_duration = 50; // milliseconds duration of dit
int dah_duration = 100; // milliseconds duration of dah
int gap_interval = 100; // milliseconds between dits & dahs
int pause_after = 500; // milliseconds between morse words
int bit_duration; // used in loop()
  // setup your I/O and other runtime values
 // sizeof() works here because morse_string][ is 8-bit bytes
 for (int counter = 0; counter < sizeof(morse_string); counter++) {
 switch (morse_string[counter]) {
 case dit:
 bit_duration = dit_duration;
 case dah:
 bit_duration = dah_duration;
 if (morse_string[counter] < gap) { // is a dit or dah
 digitalWrite(LED_BUILTIN, ON);
 delay(bit_duration); // hold dit/dah as long as required
 digitalWrite(LED_BUILTIN, OFF);
 delay(gap_interval); // gap between dit & dahs
 delay(gap_interval); // extra gap between characters
 delay(pause_after); // rest between words
For a very specific case like this, you can also try:
#define UNIT            200
#define INTER           (1*UNIT)
#define DIT             (1*UNIT)
#define DAH             (3*UNIT)
#define LETTER          (3*UNIT)
#define WORD            (7*UNIT)
#define MESSAGE         3000
unsigned long
    Delays[] =
        DIT, DIT, DIT,
        DAH, DAH, DAH,
        DIT, DIT, DIT
  pinMode( LED_BUILTIN, OUTPUT );
  digitalWrite( LED_BUILTIN, LOW );
    for( int i=0; i<3; i++ )
        for( int j=0; j<3; j++ )
            digitalWrite( LED_BUILTIN, HIGH );
            //on time for dit or dah
            delay( Delays[(i*3)+j] );
            //off time between dits/dahs of letter
            delay( INTER );
        }//for
        //time between letters
        delay( LETTER );
    }//for
    //time between messages
    delay( MESSAGE );
}//loop
Paul_KD7HB:
Look at examples of a “for” loop.
Paul
I will do that Paul, thank you!
AWOL:
if (i = 9)
Oops
i = ++i;
“i++;” is much shorter.
Ah! I didn’t know I could do that! This is precisely the type of stuff I was looking for! Thank you!
lastchancename:
Give this a shot
#define dit 0
#define dah 1
#define gap 2
#define ON HIGH
#define OFF LOW
uint8_t morse_string = {dit, dit, dit, gap, dah, dah, dah, gap, dit, dit, dit }; // SOS
// we’ll use delay here - to simplify the explanation,
case dit:
case dah:
Thank you for all that! It did indeed compile on the first try! I will have to research the array, switch / case / break & “for” functions, as someone suggested earlier. Thank you again, you have given me much to work on!
Blackfin:
#define UNIT            200
#define INTER           (1UNIT)
#define DIT             (1
UNIT)
#define DAH             (3UNIT)
#define LETTER          (3
UNIT)
unsigned long
   Delays =
       DIT, DIT, DIT,
       DAH, DAH, DAH,
       DIT, DIT, DIT
           delay( INTER );
       }//for
       delay( LETTER );
   }//for
   delay( MESSAGE );
}//loop
Thank you @Blackfin I will dig into this as well! Much to research!
