Greetings to all,
I'm looking to run a simple program such as "sweep" with two 8.4v servos:
-I am using an Arduino Uno, powered via usb from a computer which is connected to a power strip.
-The 8.0v is provided to the servos by a BEC that is also plugged into the same power strip.
-The signal wire to the servo is connected to pin 9 on the Arduino Uno
Attempting to run the "sweep" with the large servos doesn't work. If I connect a smaller servo it works. The smaller servo has a signal wire connected to pin 9, and the power and ground is connected to the Arduino Uno 5v power and ground.
Any advice would be greatly appreciated.
