First off, a quick background on myself: I have just started using arduino, but I have a diploma in Electronics Engineering Technology and work with electronics everyday (though more troubleshooting than design).
My first project is a 24 LED clock using the Solarbotics Freeduino SB board, an Atmel ATmega168 and four 74HC595 shift registers. So far I have the circuit wired up and decent code to run the 595's, but I can't get an overly accurate clock.
Currently, I'm using the MsTimer2 library to set a second flag variable every 1 second (using the timer2 interrupt I think?). The main program sits and waits for this flag, then increments the time, clears the flag and starts waiting again. I think this should work, because there is no chance that my main program will ever take more than a second to run. I know this may cause the seconds to not always update at the exact same time, but in the long-run the time should be right.
At first I had all the code that is now in the "loop" section under the timeInc interrupt funtion, but it was very inaccurate. It got alot better when I cut the interupt code down as much as possible, but still after running for only a couple of hours, the time is over a second fast when compared to the time on my PC.
Is there anyway to get more accurate timing without anything drastic?
int secTime = 0;
int minTime = 0;
int hourTime = 0;
boolean secFlag = 0; //second flag
void timeInc() {
secFlag = true; //set second flag to tell main program that 1 second
//has occured
pinMode(13, OUTPUT);
MsTimer2::set(1000, timeInc); //setup MsTimer2 to run every 1 second
MsTimer2::start();
//main program basically waits until a second has passed, then
//increments the time accordingly
if(secFlag){
if(secTime == 59){
secTime = 0;
if(minTime == 59){
minTime = 0;
if(hourTime == 11){
hourTime = 0;
else{
hourTime++;
else{
minTime ++;
else{
secTime ++;
//send time to screen
Serial.print("\e[2J");
Serial.print(hourTime);
Serial.print(":");
Serial.print(minTime);
Serial.print(":");
Serial.print(secTime);
secFlag = 0; //reset second flag
wow, I had no idea I could clean up the clock logic like that, thanks man!
Also, I have tried changing the MsTimer2::set(1000, timeInc); value, but the problem is that in two hours there are 7200000ms or 7200s, so changing the 1000 to 1001 would give me 7207200ms or 7207s in two hours; a 7s difference. 1 sec/hour error seems as good as I can get without changing my approach.
Why not get a DS1307 IC? They are very cheap and easy to use and will give accurate time. You also get the advantage that with a battery back-up it will maintain the time after a power down.
You didn't really mean to write it like that, did you?
I admit that software is my weak side but I don't get the '?' and ':' use in your above suggested code and could not find their use in the Arduino extended reference section. Is this some C++ magic?
Thanks for the explanation link. That's pretty good example of how to make something terse (dense?) at the expense of clarity. No wonder the Arduino reference left it out ;D
So the error is about 1/(2*60*60) or 138ppm off? That's not TOO far outside the normal accuracy specifications for low-cost crystals (50-100ppm) The highly though-of accuracy of crystals doesn't stand up too well to time measurement, where we're used to seconds per day accuracy (closer to 10ppm) (it COULD be a software issue; I'm not sure how mstimer2 works internally. There were issues with "delay" where it can be off by close to 1ms; used to be it could be almost 1ms less than the specified time, now it can (more safely) be up to 1ms more than the specified time.)
Could well be a software issue. In my experience, crystal controlled Arduino boards are accurate to within a few seconds per day (at room temperature).
You may want to try a test using the DateTime library and see if the accuracy improves.
The ternary syntax is useful for experienced C programmers but its obscure for Arduino users that are not C programmers (and are more interested in making projects then learning the details of a programming language)
If you're interested in doing more advanced projects with the Arduino, I think it will repay you many times over to learn how to configure a timer and its associated interrupt(s) manually. It's a real pain to figure out the first time, but get ye to the datasheet, I say.
You could use Timer1 in CTC mode with a /256 prescaler. Then the timer will tick 62,500 times per second, so you set your output compare register to 62500, and write the interrupt to increment your seconds variable every time it fires. Voila, you have a subroutine that will run exactly every 1 second, independent of how much you're loading down your processor with your main program routine.
