[Newbie] Need help with identifying usage of 3 pin LDR
Hello!
I need some help with a certain part I've bought on a trip to electronic part shops alongside plenty resistors and capacitors.
I asked if they had LDRs and they showed me a small drawer on the shelf with LDRs in them, however they all had 3 pins on them. I'm not exactly sure how to use this variation of an LDR / identify the difference in between this and a regular LDR, could you please help me?
  • The LDR is black coloured and has three pins.
  • The top of the LDR seems to have two of the patterns found on a regular 2 pin LDR, except they are vertical and connected to each other like two coiled snakes facing each other
Thanks!
Why not post a photo? Everybody has a smartphone nowadays, don't they?
Sounds like an LDR in TO72-case.
Third pin is not connected to LDR, just there for mechanical stability.
// Per.
You should be able to suss it with an ohm meter
septillion:
Photo here
Looks like 2 LDR's in series with the middle connection also brought out. So just use the outer two pins and ignor the middle. Indeed a Ohm meter should confirm.
septillion:
If that's what it is, and I thought the same, I wonder why? I suppose it could be used as 2 independent reads in the same lighting? Middle to 5V, resistor to ground from each outer pin, and each outer pin its own analog pin.
They use them to center a spot of light. You adjust the position until the light falls evenly between the two LDRs and so each one gives the same reading.
Grumpy_Mike:
exactly. Quite nifty device!
// Per.
Thanks so much for the replies!
Doubledoge:
Did you confirm the pins with your meter?
OPs picture;
Tom... :slight_smile:
