newbie needing guidance, please help
i’am hoping someone can tell me of a great tutorial series that will help my dumb a!! understand simple things, for instance i want to run multiple pir sensors on a uno micro that sends a 433mhz signal to my uno but i am not at all sure how to write code of multiple sensors to one arduino and i somehow cant find a example code or sketch. thank you
How did you write the code for one sensor? Copy/paste and change the pin number for the next sensor. When you get tired of that, use arrays.
If your answer to @PaulS's question is that you haven't figured out how to write code for one sensor then I think it would be wise to work your way through several of the examples that come with the Arduino IDE.
The Thread Planning and Implementing a Program may also help.
...E
ok, thanks for the simple tip of copy and paste another line with different pin number. i was trying to put it all in one line. i am still very open to any good tutorial series. thanks
http://forum.arduino.cc/index.php?topic=148850.0
pay very close attention to number 6
then re-read it, pay close attention on what is unhelpful.
keep posting and have fun.
