newbie needing help with buttons and loops
Hi, I have done a few button examples in some books and Im trying to do my own but I dont know how to make the state of a switch go back to low after its been pressed.
I want to have a 2 led 2 button setup that detects a sequence of 11, 12, 21 which will turn on a green led and 22 that will turn a red led on
The code is below and at serial.print(state1); the state of the button reads 1 without it being pressed.
int state1 = digitalRead(switch1);
int state2 = digitalRead(switch2);
do
  if(state1 || state2 == HIGH)
    next(state1, state2);
while(state1 && state2 == LOW);
void next(int state1, int state2)
  if(state1 == HIGH)
    digitalWrite(LED1, HIGH);
    int pin1 = 0;
    Serial.println(state1);
    delay(3000);
  if(state2 == HIGH)
    int pin1 = 1;
I'm not 100% sure what you mean.... do you mean the hardware state of a push-button being forced low once it's been released?
If so, you need a pull-down resistor as explained here, about half-way down. (Don't do it with just a wire without a resistor, since that would just short-circuit the power supply to ground and release magic smoke.)
i hope this will help too:
delay(3000);
--->check out principle of http://arduino.cc/en/Tutorial/BlinkWithoutDelay
about input state and internal pullups and stuff check out this: http://arduino.cc/en/Tutorial/DigitalPins
http://www.ladyada.net/learn/arduino/lesson2.html
http://hacking.majenko.co.uk/the-while-loop
