Hello everyone!
Alright, so I'm completely new to robotics, as well as electronics in general. However, I am a techy-"geek" guy, so I'm not completely out of my comfort zone.
Here's what I'm trying to do.. I want to build a bot (preferably tracked) that can be started in a room/house, and map out the space in 2d. After that process is done, I want it to be able to locate it's "home" - charging base - and then randomly move about.
I'm guessing a modified wall-following bot would do the trick. My question is, what hardware/sensors should I use?
Again, I'd like it to be tracked, but there's a good amount of slippage with this type of setup, yes? and getting precise readings of the space is important. Is tracked not a good idea?
Also, I know I'd need two motors and motor shield. I was looking at the AdaFruit board, though assembling it is a little daunting.
As far as the sensors go, I've seen variations using 1 ping sensor and that's it (i think), or some using up to 7 pings, or multiple IRs. Are pings more precise?
Also, for storage of the data, an SD shield would be needed too?
I have big plans for this (I like to learn by jumping into the deep end), but I figured I'd try to scale it back a bit at first.
I realize this is a bit unorganized, but I think you can get what I'm trying to do?
Thanks!
