"Newbie needs help bluetooth doorbell to mobie phone URGENT"
URGENT
Hello all,
I was wondering if anyone could help me with the project i'm doing (newbie).
I am trying to make a notification to my phone when i press the doorbell. I am using Bluetooth Module (HC-05). If someone could provide me with the source code for it to SEND notification from my ARDUINO UNO to my PHONE VIA BLUETOOTH.
If needed to use App, i can use app inventor to get the notification, or someother way.
URGENT
Here are code based on the android code to control arduino via Bluetooth
Bluetooth Module Details:
 JY-MCU Arduino Bluetooth Wireless Serial Port Module
 Default password: 1234
 Baud rate: 38400
 Dimensions: 1.73 in x 0.63 in x 0.28 in (4.4 cm x 1.6 cm x 0.7 cm)
 PINOUT
 PIN DESCRIPTION
 1 KEY
 2 VCC
 3 GND
 4 TXD
 5 RXD
 Adruino Code:
 * Bluetooth switch arduino
int state = 0;
int DoorBell = 0;  // Door Bell state
int incomingByte;
  //set pin 12 to output mode
  pinMode(12, OUTPUT);
  pinMode(2, INPUT); 	// DoorBell input
  // see if there's incoming serial data:
  if (Serial.available() > 0) {
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
    // depending on the incoming byte do the needful action
    if (incomingByte == '1') {
      digitalWrite(12, HIGH);
      Serial.println("ON");
      state=1;
    else if (incomingByte =='2') {
      digitalWrite(12, LOW);
      Serial.println("OFF");
      state = 0;
  if(state)
 // read the state of the DoorBell value:
  DoorBell = digitalRead(2);
  if(DoorBell)
    Serial.println("Door Bell Press");
    Serial.println("DoorBell not Press");
  delay(250);
URGENT Help URGENT
Is not going to get you the help you need.
You can edit the subject of this thread and I suggest you do to something like.
That way you will get the attention of bluetooth users and save a lot of others the time to see what you need but they can't help.
Tom..Goodluck.... :slight_smile:
BillHo:
Baud rate: 38400
PINOUT
PIN DESCRIPTION
1 KEY
2 VCC
3 GND
4 TXD
5 RXD
Adruino Code:
  • Bluetooth switch arduino
    int state = 0;
    int incomingByte;
          state=1;
          state = 0;
      if(state)
  if(DoorBell)
  delay(250);
Thank you very much, BillHo, Can i ask the " Serial.println("ON");" will appear where?
TomGeorge:
URGENT Help URGENT
Thank you very much, TomGeorge, for your reply. I will.
then please do it now.
I looked, but cannot help with the wireless.
change the subject line ASAP
John-Kinger:
It will appear at your phone as a serial message.
Please read the link article.
Yes I wasted time looking as well, change the heading.
Rob
