I have read the tutorials and forums but cannot figure out how to transfer a file from pc to arduino. The file is stored on the pc but how does arduino find it? I see how to read it once it gets to the serial port but how do I get it there?
The Arduino can't find it. You have to provide an application on the PC that can open the file and pass the data to the Arduino. Gobetwino (Gadgets og teknologi | Dansk Tech Blog - Mikmo) can be that application, or you can write something yourself.
Now, I understand how to transfer a file but am unclear on the file destination spec. If I want to copy the file into
Arduino EEProm how do I specify that?
I want to be able to copy files from the PC into an external EEPRom but am taking it one step at a time. But maybe directly is simpler.
It's not a 'file' that the Arduino will see, it's a stream of serial data. You will need to read the serial data, one byte at a time, and write it to sequential locations on the EEPROM.
I believe that AVRDUDE (the program used to upload programs to the Arduino) has the capability of directly writing data to the on-board EEPROM, but someone else will need to help you there, as I don't know how to do it.
If I understand this correctly then the destination I specify in Gobetwino is the serial port, same as described in Arduoino. Then I do a Serial.read() in the Arduino sketch to import the file a line at a time.
