Newbie needs help with coding a chase sequence
Hi all,
I have this code that uses a pushbutton to start a chase and I want to alter the end from all the LEDS going out at once to going off one at a time in a random manner. Could someone please help me with the code or tell me what I need to write in order to make this happen.
// A chase controlled by a button
int Button=2; //button assigned to pin 2
int timer = 100; // The higher the number, the slower the timing.
int ledPins = {
3,4,5,6,7,8,9,10 }; // an array of pin numbers to which LEDs are attached
int pinCount = 8; // the number of pins (i.e. the length of the array)
pinMode(Button, INPUT);
int thisPin;
// the array elements are numbered from 0 to (pinCount - 1).
// use a for loop to initialize each pin as an output:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(ledPins[thisPin], OUTPUT);
//turn LEDS on
while (digitalRead(Button)==HIGH);
//delay (10);
Serial.println(“LOW”);
while (digitalRead(Button)==LOW)
Serial.println(“HIGH”);
digitalWrite(ledPins[thisPin], HIGH);
delay(timer);
digitalWrite(ledPins[thisPin], LOW);
for (int thisPin = pinCount - 1; thisPin >= 0; thisPin–) {
delay(timer);
I thought it might be something like this but can’t seem to piece it together to get it to work.
// switch them randomly on and off
int someNumber = 22;
for (int i = 0; i < someNumber; i++){
int thisPin = random(3,10);
if (random(1) == 1){ // random(1) returns 0 or 1, I hope
// Finally, switch them all off
Any help much appreciated.
many thanks,
Frank
Please modify your post. Select all the code, and press the button above with the # on it.
While you are at it, put each { on a new line, and properly indent all of your code, so one can see where a block starts and ends.
Instead of hoping, you could look it up.
http://arduino.cc/en/Reference/Random
Random(1) returns a non-negative, integer, random number that is less than 1. Doesn't really leave too any choices, eh?
frankhiggins:
Hi all,
int ledPins = {
int thisPin;
//turn LEDS on
//delay (10);
delay(timer);
delay(timer);
many thanks,
Frank
Check the reference for the random(n) function. It returns a long with a value from 0 to n-1. random(1) should always return 0.
