I'm really new to using Arduino and I'm having some problems. I can load the blink program and it works fine. I downloaded a program for an antenna rotator control and it opens in the Arduino folder and sketch board. But when I go to compile it I get the following error below.
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
Using library EEPROM in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM
Using library LiquidCrystal in folder: C:\Program Files\Arduino\libraries\LiquidCrystal
Using library Wire in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Using library SPI in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI
Using library Ethernet in folder: C:\Program Files\Arduino\libraries\Ethernet
C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM -IC:\Program Files\Arduino\libraries\LiquidCrystal\src -IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files\Arduino\libraries\Ethernet\src C:\Users\Alex\AppData\Local\Temp\build6204381922051258216.tmp\k3ng_rotator_controller.cpp -o C:\Users\Alex\AppData\Local\Temp\build6204381922051258216.tmp\k3ng_rotator_controller.cpp.o
k3ng_rotator_controller.ino:400:30: fatal error: rotator_hardware.h: No such file or directory
compilation terminated.
Error compiling.
I thought I put all the necessary files in their proper folders but is not going to load due to these errors.
Can anyone help with this problem?
Any help would be greatly appreciated.
Thank you
Alex-KV4PW
