Here is the code I am working with. This code works great, BUT I am wanting to add more than 1 input - each time I do so the computer receives the actions and loops them over and over not waiting on the switch.
What I am trying to accomplish is 4 buttons connect to a Teensy 2.0 board. Each button controls different keyboard action. See code below for my 1 button example.
Update: I used the original (1 button) code from a tutorial and it works great. KEY_ENTER doesn't need defined when I press my button it sends an 'ENTER' on the screen/computer. I have played with the delays quite a bit and if I remove them is sends the actions over and over again.
// need a include here for the keyboard
#include <keyboard.h> // <-- I think ...
// missing some declaration here
pinMode(21, INPUT_PULLUP); // <-- should be pinMode(21, INPUT)
pinMode(20, INPUT_PULLUP);
delay(4000); // <--- you need 4 seconds here ?
if (digitalRead(21) == LOW)
Keyboard.set_key1(KEY_ENTER); // <- I don't see any declaration for KEY_ENTER
Keyboard.send_now();
Keyboard.set_key1(0);
delay(2500); // <-- you need 2.5 second here ?
if (digitalRead(20) == LOW)
Keyboard.set_key2(KEY_SPACE); // <-- Also I don't see any declaration for KEY_SPACE
Keyboard.set_key2(0);
delay(1000) // <-- you need 1 second here ?
delay(10); // <-- short time , only 10 mS ..that is 10 milisecond or 0.01 second , you need that ?
You are not posting your code in a code box.
Go back to modify that post. Select the code and hit the # icon, then save it.
You are not posting all you code so we can't see why you think the first one works. That to will repeat over and over, maybe something down the line is suppressing the repeat, but without all the code we can't be sure.
You are using the delay function, that means when pin 21 is held low the code won't look at pin 20 for 2.1 seconds. You need to remember the past state of the input in a variable and only do the action when the current state is low and the past state was high and get rid of all those delays.
I was able to get the code to work. Seems as though I had soldered my board wrong! I will re-solder board tomorrow and we will see what happens.
Here is the final code (should work):
// The inputs you're using for button presses
const int ENTER = 21; // ENTER
const int SPACE = 20; // SPACE
const int UP = 19; // UP
const int DOWN = 18; //DOWN
int ENTERStatus = 0;
int SPACEStatus = 0;
int UPStatus = 0;
int DOWNStatus = 0;
pinMode(ENTER, INPUT);
pinMode(SPACE, INPUT);
pinMode(UP, INPUT);
pinMode(DOWN, INPUT);
void loop(){
// Check the buttons
ENTERStatus = digitalRead(ENTER);
SPACEStatus = digitalRead(SPACE);
UPStatus = digitalRead(UP);
DOWNStatus = digitalRead(DOWN);
// If ENTER button is pressed
if (ENTERStatus == HIGH) {
// Change the following two lines to change the keys sent
// If SPACE button is pressed
if (SPACEStatus == HIGH) {
Keyboard.set_key1(KEY_SPACE);
// If UP button is pressed
if (UPStatus == HIGH) {
Keyboard.set_key1(KEY_UP);
// If DOWN button is pressed
if (DOWNStatus == HIGH) {
Keyboard.set_key1(KEY_DOWN);
int previousState;
void setup(){
previousState = digitalRead(myPin);
void loop(){
int currentState = digitalRead(myPin);
if( currentState == HIGH && previousState == LOW) { // only do this stuff once and on a rising edge
// do stuff
previousState = currentState;
