I have encountered error message,
ERROR COMPILING
In file included from LED.pde:2:
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial/SoftwareSerial.h:52: error: conflicting return type specified for ‘virtual void SoftwareSerial::write(uint8_t)’
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding ‘virtual size_t Print::write(uint8_t)’
I have connected my LED to pin 11.
Below is the code that I am using,
#include <SoftwareSerial.h>
SoftwareSerial port(12,13);
#include <EasyVR.h>
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_ARDUINO = 0,
enum Group1
G1_RECORD = 0,
G1_LED_ON = 1,
G1_LED_OFF = 2,
EasyVRBridge bridge;
int8_t group, idx;
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
port.begin(9600);
if (!easyvr.detect())
Serial.println(“EasyVR not detected!”);
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println(“EasyVR detected!”);
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; ← jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: “);
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(” = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println(“Timed out, try again…”);
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_ARDUINO:
// write your action code here
// group = GROUP_X; ← or jump to another group X for composite commands
case GROUP_1:
switch (idx)
case G1_RECORD:
case G1_LED_ON:
case G1_LED_OFF:
Thank you for the help rendered.
