newbie problem with adjustable 4 variable
may aim to set/ delta time (4-15 sec)/temp. limit (100-120c)/load press.(4.0-6.0 Bar)/unload press(6.0 - 7.5 Bar)
it is apart of compressor module
my code here
#include <EEPROM.h>
#include <LiquidCrystal.h>
const int rs= 13 , en=12 , d4= 11 , d5= 10, d6=9 , d7= 8 ;
LiquidCrystal lcd(rs , en , d4 ,d5 ,d6 , d7);
// Creates up /down custom characters for the display
byte downArrow[8] = {
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b10101, // * * *
  0b01110, //  ***
  0b00100  //   *
byte upArrow[8] = {
  0b00100, //   *
  0b01110, //  ***
  0b10101, // * * *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100, //   *
  0b00100  //   *
// this constant won't change:
    const int  buttonUp = 2;    // up
    const int  buttonDown = 4;    // down
    const int  buttonEnter = 3;    // enter
    const int  buttonSave = 6;    // save
    // Variables will change:
    int tempLimit = EEPROM.read(20); // temperature limit for alarm
    float unLoad = EEPROM.read(10); // pressure limit to unload
    float load = EEPROM.read(30); // pressure limit to load
    int starTime = EEPROM.read(40); // star to delta time
    int counter = 0 ;
    int lastChangeMode=0;
    int val;
      // Creates the byte for the 2 custom characters
  lcd.createChar(1, upArrow);
  lcd.createChar(2, downArrow);
   bool changeMode = false;
   bool tempChangeMode = false;
   bool unLoadChangeMode = false;
   bool loadChangeMode = false;
   bool starChangeMode = false;
setting();
getCounter();
int setting(){
  int enterButton = digitalRead(buttonEnter); // enter
  if(enterButton == HIGH) {
     lastChangeMode = 1;
     if(lastChangeMode != changeMode){
      changeMode = true;
    else(changeMode= false);
  if(changeMode) {
     int upButton = digitalRead(buttonUp); //up
     int downButton = digitalRead(buttonDown); // down
    if (upButton == HIGH) {
      counter ++ ;
      if (counter>4)counter=4;
      delay(200);
    if (downButton == HIGH) {
       counter --;
       if (counter<1)counter=1;
      delay(200);
  return counter;
void getCounter(){
     val= counter;
     switch(val){
    case 0:
     drawInstructions();
     case 1:
     lcd.setCursor(0,1);
    lcd.print("Unload prs "+String(unLoad));
    delay(150);
    drawInstructions();
    getUnLoad();
    case 2:
    lcd.setCursor(0,1);
    lcd.print("Load prs "+String(load));
    delay(150);
    getLoad();
    case 3:
    lcd.setCursor(0,1);
    lcd.print("temp limit "+String(tempLimit));
    delay(150);
    getTempLimit();
    case 4:
     lcd.setCursor(0,1);
    lcd.print("Star time " + String(starTime));
    delay(150);
    getStarTime();
   void getLoad(){
    loadChangeMode = true ;
  int saveButton = digitalRead(buttonSave); // save
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Load: " + String(load) + " Bar");
      drawInstructions();
      while(loadChangeMode){
        float loadCounter = load ;
        if(upButton == HIGH){
          loadCounter = loadCounter + 0.1 ;
          constrain(loadCounter , 4.0 , 6.0 );
       if(downButton == HIGH){
        loadCounter = loadCounter - 0.1 ;
        constrain(loadCounter , 4 , 6 );
       if (saveButton == HIGH){
        EEPROM.update(30 , loadCounter);
        delay(10);
        loadChangeMode = false ;
        lcd.setCursor(0,1);
        lcd.print("**Data saved**");
        lcd.clear();
       if (enterButton == HIGH){
        lcd.clear();
   void getUnLoad(){
    unLoadChangeMode = true;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Unload: " + String(unLoad) + " Bar");
      while(unLoadChangeMode){
        float unLoadCounter = unLoad  ;
          unLoadCounter = unLoadCounter + 0.1 ;
          constrain(unLoadCounter , load , 7.5 );
        unLoadCounter = unLoadCounter - 0.1 ;
        EEPROM.update(10 , unLoadCounter);
        delay(10);
        unLoadChangeMode = false ;
        lcd.setCursor(0,1);
        lcd.clear();
        lcd.clear();
   void getTempLimit(){
         tempChangeMode = true;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("temp Limt: " + String(tempLimit) + " C");
      while(tempChangeMode){
        int tempCounter = tempLimit  ;
          tempCounter = tempCounter + 1 ;
          constrain(tempCounter , 100 , 120 );
        tempCounter = tempCounter - 1 ;
        EEPROM.update(20 , tempCounter);
        delay(10);
        tempChangeMode = false ;
        lcd.setCursor(0,1);
        lcd.clear();
        lcd.clear();
   void getStarTime(){
        starChangeMode = true;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Star time " + String(starTime) + " Sec");
      while(starChangeMode){
        int starCounter = starTime ;
          starCounter = starCounter + 1 ;
          constrain(starCounter , 3 , 15 );
        starCounter = starCounter - 1 ;
        EEPROM.update( 5 , starCounter);
        delay(10);
        starChangeMode = false ;
        lcd.setCursor(0,1);
        lcd.clear();
        lcd.clear();
    void drawInstructions() {
  lcd.setCursor(0, 1); // Set cursor to the bottom line
  lcd.print("Use ");
  lcd.write(byte(1)); // Up arrow
  lcd.print(" / ");
  lcd.write(byte(2)); // Down arrow
  lcd.print(" buttons");
the counter work fine from 1 to 4 when setting function only on the loop
when i add getCounter function i had to press enterbutton with up or down to work
and when i release it i cant back to setting mode any more ..... excuse me for my bad english
Any advice would be greatly appreciated.
You will have to explain how your program is supposed to work. What is each function intended to do?
It looks to me as if you need to re-design your code to separate the user input code from the action code. That way you will be able to test each part on its own.
...R
Planning and Implementing a Program
